[IL] New Comp XE274 Cam, 400 Rotating Assembly + A Whole Bunch Of Misc. Goodies For Sale
Old Aug 16, 2012 | 09:57 PM
SoCo80p's Avatar
New comp cams XE274 cam and lifter set, $180 shipped
Balanced rotating assembly for chevrolet 400 small blocks bored .030 (406). The assembly includes an eagle crank, ATI superdamper, SFI approved TCI flexplate with ARP bolts, 6" eagle "ESP" H-beam rods, Wiseco forged flat top pistons, plasma moly rings, clevite H series rod bearings, and the assembly has been professionally balanced. Will take $1,400 for everything.
0-100 lb. heavy duty scale $35
4 piece taylor wire set $10
Sears power drill $20
1" open carb spacer $12 - Sold
MSD hei to hei plug style coil wire $8
extra large trans cooler $30
Pair of new in the plastic Pioneer 6x9" speaker grilles $20 - Sold
Chrome alternator bracket X2 $15
Chrome radiator hose neck $5
Dwell/points/tach meter $20
Hard to find reclining seat bar $65
Chrome distributor hold down $5
Chrome fuel pump block off plate $7
4 piece new in the package keystone offset washers for GM cars $7
70-81 firebird glove box door $20
re-pop battery tray with holddown $15
Pair of leaf spring shackle bushings $10
New spreadbore carburetor gasket $3
Chrome timing pointer with adjustable pointer for small block $5
Pair of 8 AN lines with fittings, $25 - Sold
Unknown brand tach $10 - Sold
5 piece trans am dash plate ring set $12
Proform 15" electric fan with built in shroud and adjustable automatic on/off, brand new in the box $125
Old Aug 20, 2012 | 09:11 AM
SoCo80p's Avatar
Re: Various Misc. Goodies For Sale
AN lines and tach are sold
Old Aug 31, 2012 | 09:05 AM
SoCo80p's Avatar
Re: New Brodix IK heads, Comp XE274 Cam, + A Whole Bunch Of Misc. Goodies For Sale
up.
Old Aug 31, 2012 | 09:46 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
What lift are the springs on the heads rated at? Have they been o-ringed? Or is that a gasket impression around each chamber?
Old Aug 31, 2012 | 03:55 PM
SoCo80p's Avatar
PM sent
Old Sep 3, 2012 | 02:08 PM
SoCo80p's Avatar
Bump
Old Sep 3, 2012 | 06:35 PM
acr's Avatar
acr
Same question about heads as wesilva asked.
Old Sep 3, 2012 | 10:21 PM
SoCo80p's Avatar
The springs are good to .525 lift. Also the heads have not been o-ringed, that is just a gasket impression on the head from mockup.
Old Sep 7, 2012 | 12:53 PM
SoCo80p's Avatar
Bump-a-roonie
Old Sep 8, 2012 | 11:20 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
1000, is that what you paid for it? I seen Patriot Heads for sale for 925, are they better than these? https://www.patriot-performance.com/...&cat=40&page=1
Old Sep 9, 2012 | 12:10 AM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
What are the dimensions on the tranny cooler?
Old Sep 9, 2012 | 02:17 PM
SoCo80p's Avatar
It measures 14 1/2" x 10" x 1"
Old Sep 15, 2012 | 12:28 AM
SoCo80p's Avatar
Re: New Comp XE274 Cam, + A Whole Bunch Of Misc. Goodies For Sale
back up
Old Sep 26, 2012 | 04:28 AM
SoCo80p's Avatar
Bump
Old Nov 19, 2012 | 07:52 AM
SoCo80p's Avatar
Up again
Old Nov 22, 2012 | 10:44 PM
SoCo80p's Avatar
bump
Old Dec 5, 2012 | 06:38 AM
SoCo80p's Avatar
back up
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
