[OH] 91 GTA 10 bolt rearend
Old Sep 13, 2012 | 07:12 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
I have nowhere to put it, so it needs to go. It is 3.23 posi with drum brakes. It makes a whirring when driving, sounds like a bearing, but it works perfectly at the moment. E brake cables and brakes included.
$150 picked up OBO.
Attached Thumbnails 91 GTA 10 bolt rearend-2012-09-13_17-28
Old Sep 15, 2012 | 11:56 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 91 GTA 10 bolt rearend
What posi units were in those rears? The name
Old Sep 16, 2012 | 12:02 AM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Auburn
Old Sep 16, 2012 | 02:13 PM
fasteddi's Avatar
Car: 1991 Camaro RS
How bad is it wineing?? Is that the gears doing that or the differential??
Old Sep 16, 2012 | 05:28 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
It was getting fairly loud when I finally swapped it. Not sure what is causing it, but I did recently change the fluid due to the noise and everything looked fine with the gears.
Old Sep 16, 2012 | 05:30 PM
fasteddi's Avatar
Car: 1991 Camaro RS
was it still locking up posi??? Im not sure what could be makign that noise but I need some sort of posi come spring and you live arround so im really entertaining getting yours if i knew what was wrong with it.
Old Sep 16, 2012 | 05:47 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Yep, worked perfectly.
Old Sep 16, 2012 | 08:05 PM
CradleofFilth08's Avatar
Car: 1992 Camaro Z28
Transmission: 86' 700R4
Axle/Gears: 10 Bolt, 3.42's
Sounds like your pinion is ready to go.
Old Sep 16, 2012 | 08:14 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
You mean the pinion bearing? The gears looked perfectly fine, and it really does sound like a bearing to me. I could be wrong, but that's what I think it is.
Old Sep 16, 2012 | 08:21 PM
Nope, the pinion. If what you mean by whining is that it sounds like you're passing by a tractor trailer while riding over a bridge or listening to a jet land then it's your pinion. Had the same thing happen to me, I thought it was my trans when I first heard the noise but after a week, my rearend went. The pinion shattered and ate up my gear.
Old Sep 16, 2012 | 08:24 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Whirring, not whining. Sounds just like a bad wheel bearing basically, to me at least.
Old Sep 16, 2012 | 08:28 PM
Oh, well then hopefully that's what that is.
Old Sep 20, 2012 | 01:29 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
bump
Old Sep 27, 2012 | 10:42 AM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
TTT
Old Nov 8, 2012 | 08:35 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
$75, complete drum to drum. Come get it.
Old Nov 8, 2012 | 08:56 PM
91z28ss's Avatar
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
I heard the same whinning sound in my rear end and a spring came out of the Auburn carrier and the pinion broke, the sound became louder and louder after short period of time and then, it broke!!! I wouldn't bolt it without investigating further for this mysterious sound!!! Good luck
Old Nov 8, 2012 | 09:00 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
This has taken 1.5 years to get loud enough for me to change it. We checked everything in the center when we changed the fluid , all looked good.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
earlpote
Aug 28, 2015 10:42 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
