[GA] 350 HO Short Block with oil pan and camshaft Make offer 500 miles since bought.
Car: 1989 RS
Engine: 350 HO
Transmission: 700r4 pheonix trans rated 500hp
350 HO has all internals and oil pan does not inlude heads and intake. Engine was in my camaro for about 500 miles after I purchased it than decided to part out the car kept the engine to sell seperate. MAKE ME AN HONEST OFFER. I bought the engine for 3 grand off of JEGS with heads on it. Only has about 500 miles on engine so really it is just broke in Ran nothing but royal purple oil through the engine. If you want pictures or have any questions just send me an email or text or call 207-twosevenfour-977four.
CASH OR PAYPAL ONLY
PICKUP ONLY I don't have a truck, I do have an engine hoist and can get it in the truck for you.
Displacement: ....................................... 350 cubic inches
Bore x Stroke: ....................................... 4.00 inch x 3.48 inch
Compression.......................................... 9.1:1
Block: .................................................... Cast iron, four-bolt intermediate mains
Crankshaft: ............................................ Nodular iron, 1 piece rear seal
Connecting Rods: .................................. Forged, powdered metal, 3/8" bolts
Pistons: ................................................. Cast aluminum
Rings: .................................................... Moly coated cast iron
Camshaft: .............................................. Hydraulic flat tappet
Lift: .435" intake, .460" exhaust
Duration:.......................................... 212° intake, 222° exhaust @ .050" tappet lift
Centerline: ....................................... 109° ATDC intake, 116° BTDC exhaust
CASH OR PAYPAL ONLY
Car: 1989 RS
Engine: 350 HO
Re: 350 HO Short Block with oil pan and camshaft Make offer 500 miles since bought.
Bump Asking 1250.00 Call for more info also comes with the stamped steeel rockers, valve springs, valves and the pushrods for the cam installed with vortec heads. I also have a mallory vaccum advance distributor long tube ceramic coated hedman headers 1 5/8 with a 3in collector, MSD Strteetfire plug wires. And the vortec chrome valve covers. Have everything but carb intake and heads to make a complete engine if you can find some vortecs that need rebuild the engine comes with everything but the valve seals to build a set.. Engine also has most sensors in the block still from 89 camaro.
Car: 1989 RS
Engine: 350 HO
Bump
$900 takes it home. Want it out of the garage.
