[OH] freshly rebuilt 355 12 second motor
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
here is the build thread
https://www.thirdgen.org/forums/engi...d-install.html
all the parts were brand new. it will come intake to pan, i will include the whole front acc drive. including a new tuff stuff 140amp 1 wire alt, and an ac delete and smog pump delete pulley. i believe there is a video of the car running with this motor on the thread page. i have all of my reciepts for all of the motor parts also. i am in the process of building a tt motor for it and putting my 72 chevelle back together so i have no use for this motor. but i will not give it away, it has sat for about 2 months after putting less than 250 miles on it. so it can sit for a year or 2 until i find another car to put it in. i will include the hedman longtube headers with it, there is 1 o2 bung welded on the driver side. if you want the full exhaust i will sell it for 300, i have 550 in materials plus time.
asking 2500 for the complete engine.
thanks,
justin
419 889 9025
thanks,
justin
419 889 9025
Car: 1991 camaro rs
Axle/Gears: 3.42s
Re: freshly rebuilt 355 12 second motor
specs of motor
9.4 compression
new vortec heads cut guides and aftermarket springs
lunati 60103 cam
stock rods/crank
hv oil pump
comp pro mag 1.52 rockers
jegs champion 331 vortec intake
everything was new, i started with a bare block
summit hv water pump & new damper
includes ps pump and lines also.
9.4 compression
lunati 60103 cam
stock rods/crank
hv oil pump
Car: 1991 camaro rs
Axle/Gears: 3.42s
bump
make an offer
if you mill the heads the full .040 that they can be it will raise compression to almost 10.5:1 making a lot more power
make an offer
ambainb
Apr 25, 2016 09:21 PM
