[CO] reprogram Tpi Maf memcal service
Old Jan 25, 2013 | 07:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
This is to help out a member to change his stock tuning to 89 $6e tune , delete vats, and this will eliminate his 9th injector.
Old Jan 25, 2013 | 07:54 PM
Coolwheels84's Avatar
Car: 84 SC Camaro (92 Tribute)
Engine: V6
Transmission: M5
Re: reprogram Tpi Maf memcal service
Good deal man. I'll send the prom as soon as I can.
Thanks. Jamie
Old Jan 25, 2013 | 08:20 PM
Engine: Lb9
Transmission: M20
Old Jan 25, 2013 | 08:55 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Whats that adapter thing he is mentioning at the bottom of the page ?
Old Jan 25, 2013 | 09:03 PM
Engine: Lb9
Transmission: M20
The moates g1 is a piggyback adapter it moves the eprom over so the ecm is reading that information instead of reprograming the eprom on the memcal.
http://www.moates.net/g1-memory-adap...-etc-p-32.html
Old Jan 25, 2013 | 10:34 PM
Jetmeck's Avatar
That still fits in the factory location ?
Old Jan 25, 2013 | 10:37 PM
Engine: Lb9
Transmission: M20
It does but requires the blue memcal cover to be removed for clearance.
Old Jan 25, 2013 | 11:16 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Good choice Jamie, Brian is top notch.
Old Jan 25, 2013 | 11:52 PM
Engine: Lb9
Transmission: M20
Thanks serge
Old Jan 25, 2013 | 11:57 PM
Jetmeck's Avatar
So in what cases would you need this thing and do you just leave it open without a cover ?
Old Jan 26, 2013 | 12:16 AM
Engine: Lb9
Transmission: M20
The moates g1 is a piggyback adapter so if you ever wanted to revert back to stock programing you remove it. The memcal access cover will still go back on the ecm with the moates adapter. I can even unsolder your stock chip and install one of the dip adapters so the eprom can be easily removed.Name:  IMG_0440.jpg
Old Jan 26, 2013 | 12:55 AM
Jetmeck's Avatar
Pretty cool stuff and intricate soldering..........that in itself is not easy.
Then there is the programming...............
50 bucks include the adapter and eprom ?
You still need the factory one sent to you ?
Old Jan 26, 2013 | 12:56 AM
Jetmeck's Avatar
Removable eprom or adapter ?
Which is recommended ?
Same price ?
Old Jan 26, 2013 | 01:01 AM
Engine: Lb9
Transmission: M20
I havent updated my flyer but it is just the cost of the dip so a extra $2.00 and no charge for me to solder it in on your memcal. The $50 I would send you a chip to put in the adapter you would need to purchase at moates.net and the $65 would be if you sent me your memcal in and I reprogram the chip on it.
Old Jan 26, 2013 | 01:26 AM
Jetmeck's Avatar
Does the adpter solder onto the stock prom ?
Old Jan 26, 2013 | 01:33 AM
Engine: Lb9
Transmission: M20
The dip socket shown in post 11 I do solder those in it is a moates d2. The stock eprom is soldered in as well. The eproms I use are like the stock eprom and are called uv erasable I also have eeprom that are flash proms a newer technology so if you ever wanted to reprogram the chip you could purchase moates.net burn 2. I just charge the cost of those chips $5 the uv erasable ones are very inexpensive so I include them if you have me install a dip socket.
Old Jan 26, 2013 | 02:11 AM
Jetmeck's Avatar
Sorry about all the questions. Have two of these needing reprogrammed.
How does the adapter attach to the factory setup as shown in the picture ?
solder ?
Old Jan 26, 2013 | 02:15 AM
Engine: Lb9
Transmission: M20
No problem I assume you mean post #5 picture it has male pins that connect into your factory memcal and the green board will go into the memcal holder in the ecm.
This link shows the installation in detail.
http://test.blundar.com/g1/
Old Jan 26, 2013 | 03:38 AM
Engine: Lb9
Transmission: M20
I do have one last option That may make things easier. I have memcals that I could prepare and would be replacements for yours if you buy two I would lower the price to 100 shipped. I start out with 3.1L v6 and modify them to work for tuned port. They are fully functional but the limp home mode is not as good as a real tpi v8. These are bench tested and I stand behind my work if you are unsatisfied I will try to correct the situation or give a full refund.
Old Jan 26, 2013 | 09:33 AM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Tunedperformanc a lot of knowledge Great guy .. Won't be let down by him..great service... I used his memcal service and I had ZERO issues...
And he does stand behind his work !
Have great weekend guys
Old Jan 27, 2013 | 03:06 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Brian is INDEED a great guy, and he is as honest as others have stated :-). I would NOT hessitate in using a PROM reprogrammed by him.
Old May 20, 2017 | 06:41 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
yeah. Brian is the go to man when it comes to bin files.
Old May 20, 2017 | 09:36 PM
Z28/ZR1's Avatar
Brian aka Tuned Performance is the best. This forum is very lucky to have him. 100% stand up guy.
Old Jun 23, 2017 | 02:02 PM
Engine: Lb9
Transmission: M20
Thanks guys, I'm happy to be involved with a great community
Old Jun 23, 2017 | 02:54 PM
Mike 92LX's Avatar
I agree. He did one for my 88 Vette.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
