[ON] Garage cleanup
Old Mar 13, 2013 | 12:29 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Garage cleanup
Couple Parts for Sale that I no longer need. Everything is plus shipping. ****New Parts Added****
2x 87-89 350 ESC. Great shape, pulled from my car and no longer need it. Other was pulled from a car that was being parted. Car ran when it was pulled. $40 ea
85-89 TPI plenum. Stock, except for EGR walls have been ground off. One screw for dizzy cover has broken and needs to be removed. $60
Plastic Distributor cover. No cracks. $15
86-87 Large Cap HEI distributor for TPI. Has new module, hypertech cap and coil. Going to a small cap and remote coil $60
86 TPI lower intake base. Stock $60
86-88 TPI runners. They have been cut as I was going to siamese them, but have gone a different route. Good project if someone would want to finish it. Includes runners and filler material/plates to be welded. $40
85-88 Throttle Bodies. I have 2 of them. One is completely stock and the other was attempted to be bored out but does not seal properly. Looking for $60 for the stock one and $40 for the other(good core).
Camaro manual vents. Comes with both insert boxes as well as cables and under dash levers. In good shape. $30
2x '7165 ecm. In working order, pulled from my car. Other was a spare. No memcal. Going SD $50ea
Maf sensor. Genuine Bosch sensor excellent shape, rear maf screen has been pulled, front is still intact. $100
Long Tube headers. Not sure what brand they are, but I had to modify them to make them fit. Primaries were notched to angle them properly to fit between the frame rails. New collectors on them as well. O2 bung welded on driver collector. Ceramic coated as well. Header flange needs to be ground flat as I can get about a year and a half before it blows a gasket out. One primary has a crack that needs to be fixed as well near collector $200
TPI fuel rail. front feed line has been cut off but is included. Was going to convert the rails to -an fittings but have gone a different route. Everything is included, only thing missing is one torx screw that holds the regulator cover on. $80
TPI Maf boots. Have 3 of them one has a crack where the clamp holds it to the TB. Others are fine. $15 for ripped one, $25 for other good ones.
vBelt setup for an 85-87 TPI. Comes with all the brackets, alt, waterpump, power steering pump and pulleys. $120
82-84 Z28 front and rear bumper cover. Also comes with front rebar/impact bar and front marker lights. Good condition, no rips. $120
82-92 Camaro tailights, non grid style. No cracks, have a couple to choose from. $60 pair
Also have 2 87 SC, 89 RS and an 84 Z28 parts cars. Let me know if there is anything specific and I will see if I can get it.
Pictures can be sent to you via email. Send me a PM with your email address and I will send the pics. Thanks
Old Mar 13, 2013 | 12:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Garage cleanup
Too bad your in the great white north or I would take the dizzy cover just don't want to pay much more than 15 for a plastic one.
Old Mar 13, 2013 | 09:15 PM
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
Re: Garage cleanup
Originally Posted by hrspwr
87-89 350 ESC. Great shape, pulled from my car and no longer need it. $40
86-89 305 ESC. Great shape, pulled from a car that I purchased a harness of of. Car ran when it was pulled.
Kinda of a newb to 3 rd gens, so please excuse my ignorance, but what is the "ESC" you are referring to?
Won't ever know if you don't ever ask.....
Old Mar 13, 2013 | 09:17 PM
Engine: Lb9
Transmission: M20
Re: Garage cleanup
Electronic spark control works in conjunction with the knock sensor . When a knock is detected the the ecm will retard the timing.
Old Mar 13, 2013 | 09:44 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Re: Garage cleanup
Is the 350 ESC coded HKR? If so, I'll give you $40 total for it. Thanks!
Old Mar 15, 2013 | 03:57 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Garage cleanup
It appears I made a mistake and will fix the above, I have two 350 ESC modules, part number 16052401. One of them does have the HKR code on a white sticker the other has nothing. Get me your zip and I can split shipping with you.
Old Mar 19, 2013 | 10:50 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Garage cleanup
TTT
Old Mar 19, 2013 | 11:20 AM
Engine: 385
Re: Garage cleanup
Sorry, I have to withdraw my offer. Tuned performance got me one for $35.
Old Mar 21, 2013 | 10:27 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Garage cleanup
Pictures of hei?
Old Mar 22, 2013 | 08:02 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Garage cleanup
PM Sent.
Old Mar 28, 2013 | 10:43 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Garage cleanup
TTT
Old Apr 1, 2013 | 09:25 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Garage cleanup
ttt
Old Apr 2, 2013 | 02:03 AM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
Re: Garage cleanup
Any chance you have the C100 engine pigtail from a 87 Camaro. PM me if you do. Thanks
Old Apr 22, 2013 | 08:03 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Garage cleanup
TTT
Old May 31, 2013 | 01:24 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Garage cleanup
Power steering pump sold. TTT
Ed1LE
Sep 30, 2018 09:14 AM
Lbibb
May 5, 2016 12:00 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
Linson
Oct 1, 2015 09:50 PM
meeklay812
Oct 1, 2015 03:46 PM
