[CO] Trade tpi ecm and memcal
Old Mar 25, 2013 | 12:53 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
For trade a 1227730 ecm and reprogramed memcal for tpi speed density for a mild 350 aujp broadcast code , auto trans. Vats, and emissions delete fans on 200f off 185f. In trade for a 1227165 ecm and memcal.
Old Mar 25, 2013 | 01:14 PM
88gunmetalgta's Avatar
Re: Trade tpi ecm and memcal
Good trade for someone looking to go SD. I have a 165 ECM and AKFS memcal, all I'd need is the other memcal in exchange for limp home on my EBL if no one else speaks up.
Old Mar 25, 2013 | 01:20 PM
Engine: Lb9
Transmission: M20
I didn't want to call out the member who I am doing the trade with but itd spoken for. I didn't think ebl had lhm
Old Mar 25, 2013 | 01:33 PM
It does indeed. Granted it runs like crap, but my cars far from stock. All I use it for is re flashing while idling or coasting without the engine dying.
That '165 is all yours if you want it anyway lol. It's just collecting dust.
Old Mar 25, 2013 | 01:42 PM
Engine: Lb9
Transmission: M20
I wonder if your tpi maf memcal would work for lhm, the I/o and netress were the same in 89 for tpi maf as the sd memcals so I would assume it would do the trick even if there are numbered 16055375 and 16055376, sending you a pm
Old Mar 25, 2013 | 01:59 PM
I am currently using my MAF memcal in the EBL. Like i said, it runs rough, but does stay running. AFR dips to 12:1, and I'm kinda curious to know what my spark advance does lol. Maybe I'll have to force lhm and put a timing light on it.
Old Mar 25, 2013 | 02:38 PM
Engine: Lb9
Transmission: M20
I wonder if it just goes to a base no computer controlled setting, btw thanks man
Old Mar 25, 2013 | 08:27 PM
That sounds likely. No problem, everyone around here is running 24x at least, that thing would never have gotten put to use.
Old Apr 7, 2013 | 08:08 AM
gbettner's Avatar
From: Close to Boggstown Indiana ( out in the middle of a corn field)
Car: 89 Iroc, saved from scrapyard
Engine: 350 vortec w/stealth ram
Transmission: 85 corvette 700r4
Axle/Gears: 3.73 posi
Traded! Thanks Tunedperformanc! ( looks like I'm FINALLY able to post in this thread)
Old Apr 7, 2013 | 10:24 AM
Engine: Lb9
Transmission: M20
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
BOOT77
Aug 10, 2015 12:20 PM
