[NH] Complete T56 Swap
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
Complete T56 Swap
This LS1 style T56 was removed from a 2001 Camaro with 61k miles on it.
It comes with:
Bellhousing
Transmission
Flywheel
Clutch/Pressure Plate
Slave Cylinder (Brand New)
Cross member
Torque Arm Mount
4th gen center console insert (pictured)
Floor mounted rubber shift boot
Factory shifter
Hurst Shifter
If you are swapping to a T56 from an auto you will also need:
Clutch pedal
Cluster master cylinder
Looking to get $1900 for the complete set up.
If you want this shipped I have two options:
UPS.com
150lbs shipping from 03076
- or -
Go to www.rlcarriers.com for a shipping quote.
Step 1 - Origin Information:
Pickup Zip Code: 03076 (Pelham, NH)
Select Residential Pickup
Step 3 - Shipment Information:
Class: 85.0
Weight: 150
PM me with interest - serious inquries only.
It comes with:
Bellhousing
Transmission
Flywheel
Cross member
Torque Arm Mount
Factory shifter
Hurst Shifter
Clutch pedal
UPS.com
- or -
Class: 85.0
Weight: 150
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
