[PA] 165 ecm w/ Chip, Slave Set up, Ported Plenum 90-92, Flywheel Clutch Kit, TPI Air Box
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
For Sale,
1227165 MAF ECM 86-89, with Hypertech Chip $70
Slave Cylinder Set up, worked when removed, $60
TPI Ported plenum, for years 90-92 with MAP sensor, $75
GM Performance Parts Flwheel for 86 up 1 piece rear main seal motor $75
Hayes Clutch Kit, pulled from car with about 10k miles, $50
TPI Air Box, Top and Bottom, $50
Can send pictures if you would like to see something. Thanks
Car: 86 and 87 Iroc's
Engine: 350 TPI's
Transmission: 700R4's
Axle/Gears: 3:23's
Re: 165 ecm w/ Chip, Slave Set up, Ported Plenum 90-92, Flywheel Clutch Kit, TPI Air
For Sale,
88SS6SPEED
Nov 11, 2015 07:05 AM
