[VA] MSD Digital 6 Ignition box and other stuff
Old May 21, 2013 | 10:36 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Summit Vacuum canister
$50
Nitrous Outlet Solenoid brackets and fuel block that goes on your fuel rail.
TPI coil brackets and dizzy hold down: $20
alls kinds of bolts off a TPI motor: $25
TPI injector Clips: $10
gaskets and wires looms and other stuff: $20
82-92 DRIVERS T-TOP Triple A-Pillar: $100
Comes with 2 digital gauges air/fuel and trans temp the bottom pod is empty. This pillar is in PERFECT SHAPE! i bet you wont find a better triple pillar pod. in the picture the color looks off but its not...the color matches perfect.
Old May 21, 2013 | 11:35 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: MSD Digital 6 Ignition box and other stuff
Interested in the Digital 6 and the wire looms. PM forthcoming.
Old May 22, 2013 | 08:58 AM
H&R Trak+ 1" wheel spacers $100.00
Old May 22, 2013 | 09:06 AM
cruise Control: $25
Turn downs: $25
BBK under alternator pulley: $15
Old May 23, 2013 | 06:25 PM
fuel pump SOLD
Old Jun 2, 2013 | 06:25 AM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
does the a-pillar guages come with sending units?
What brand are the guages?
Old Jun 2, 2013 | 07:23 AM
the air/fuel doesnt need a gauge...it taps into your O2 sensor wires and the trans temp gauge " needs a sending unit" the other was left in the trans pan before i sold the car.
I cant really remember what kind of gauges, I think the trans is a Cyberdyne and the air/fuel is a jegs? or summit...cant remember
Old Jun 2, 2013 | 08:23 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Ill take that 6al digital right now. PM me! Thanks
Old Jun 2, 2013 | 08:26 AM
pm sent
Old Jun 2, 2013 | 08:43 AM
Guest
Guest
Posts: n/a
What gauge is on that vacuum can? A vacuum gauge I presume. Any close up pics of that?
Old Jun 2, 2013 | 09:01 AM
MSD Digital 6 box......SOLD!
Old Jun 2, 2013 | 03:01 PM
damn sorry bud I didnt see this post until now or i would have sent pictures out sooner.
Its just a standard Summit vacuum gauge, yes.
Here are some close up pictures.
thanks
Old Jun 2, 2013 | 03:16 PM
Guest
Guest
Posts: n/a
How would you empty that, id assume theirs cap of some sort somewhere?
Old Jun 2, 2013 | 03:47 PM
yeah its got a fitting on the bottom. I dont know why the gauge is showing pressure cause the tank is empty and i can blow in the fittings and air comes out the other.
Maybe its gotta pressurize to zero itself out...IDK
I didnt have it connected long at all cause i sold the car but when it was connected it showed like 20psi or something..cant remember.
I also have enough hose to go from the brake booster back to the tank and the vacuum fitting on the back of the plenum depending on where you mount the tank.
I had it mounted in the front where the cruise control was.
http://www.summitracing.com/parts/su...FYuk4AodrzIAfQ
Old Jun 4, 2013 | 04:53 PM
project89's Avatar
still have the nitrous fuel block? i take it it just screws down tot he shrader valve?
how much
Old Jun 4, 2013 | 07:38 PM
yeah just screws onto the schrader valve. Im assuming, LS, LT1 and SBC valves are the same size? I had an extra one..I used the same on my LS motor.
$30.00 plus shipping.
Old Jun 4, 2013 | 07:58 PM
project89's Avatar
i think there the same
is the log part of it taped for pipe thread on the ends?or is that an an fitting nexto the shrader valve part ?
im just looking for a simple way to permantly mount up a fuel presure sending unit on my rail for my ecm
Old Jun 4, 2013 | 10:36 PM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
I will take the injector clips and engine bolts. PM me with your payment information.
Old Jun 8, 2013 | 09:57 PM
sorry bud, had to go out of town for work.
on the end is a 1/8 npt and the silver fitting you see is also a 1/8 npt thread. the black part goes on the fuel rail.
so there are 2 npt threaded parts.
Old Jun 14, 2013 | 09:33 PM
shift light ...SOLD!
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
overdriv
Aug 20, 2015 03:52 PM
tartagliaz28
Aug 15, 2015 10:59 AM
