[FL] F/S 350 sbc 1 piece or two piece rear. Billet mains $300
Old Jun 23, 2013 | 01:16 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Ok here are the specs on the motor. It is a 4 bolt billet main block. Is a roller block with acl ceramic bearings in it still. It is bored .040 over and is clearanced to handle a 3.875 stroke crank. All oil passages have Ben drilled and tapped and plugged and has been setup for optimal oil flow. It is originally a 1 piece rear main block but has a 2 piece adapter plate that comes with it. Has a melling high volume oil pump and arp main studs on it. It's in great condition and will be pick up only. I have pictures I can email you if interested.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
BBSDesigns
Aug 11, 2015 07:39 PM
