T56 6 speed swap, AFR Heads, Holley Stealthram, Mufflex Magnaflow, 383
Old Jul 2, 2013 | 10:15 PM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
All parts came from a 1989 Pontiac Trans Am GTA. See links for exact specs on some of the parts. I would prefer local pick up if possible due to the size and weight of the parts, I'm located near Milwaukee WI, I would consider possible shipping options though. Any questions call 262-894-5664, NO texting please.
Here is a link to my craigslist add that has some pictures.
http://milwaukee.craigslist.org/pts/3910644762.html
SOLD==Hawks Thirdgen trans crossmember for 3rd gen fbody
SOLD==LT1 T56 6 speed trans with bellhousing (very smooth shifting), 4th gen pedals, electrical connectors, Starter with bolts, GM clutch master cylinder and slave cylinder. All 6 speed swap parts for $1550obo
SOLD==Ram Power Grip clutch disc with pressure plate and through-out bearing (rated at over 500ftlb), with GM flywheel. Less then 2000 miles on this setup, $350obo
http://www.summitracing.com/parts/ra...w/make/pontiac
SOLD==Dougs (same design as Hooker) Long Tube Ceramic Coated Headers (part #D3321)1 3/4" with 3" collectors, custom 3" off-road Y-pipe into a single 4". Y-pipe will fit t56 and automatic trans and crossmembers. $500obo
http://www.summitracing.com/parts/dou-d3321
SOLD==Mufflex exhaust with the MagnaFlow straight through race muffler option.
SOLD==Holley StealthRam intake manifold with all vacuum fittings, throttle body and sensors, Holley fuel rail kit and Kirban Billet adjustable fuel pressure regulator, -6 braided stainless steel fuel lines with AN fitting for direct hook up to a 3rd gen fbody, The intake manifold was milled by LAM engines to fit under the stock GTA hood. Less then 50 miles. All intake/fuel parts for $500obo
http://www.summitracing.com/parts/wnd-7540/overview/
http://www.summitracing.com/parts/hly-534-186/overview/
http://www.kirbanperformance.com/pro...R+%236547.html
SOLD==AFR 195 Heads, upgraded 7/16" rocker studs, shimmed valve springs for .576 lift cam, excellent condition, Just gone through at LAM engines 50 miles ago, come with ARP head bolts, $1250obo
http://www.summitracing.com/parts/afr-1041/overview/
==Comp 280 XFI (230/236 .576/.570) small base circle to fit in a 383 stroker (will also work on non-stroked engine) double roller timing chain, and Comp push rods. Less then 50 miles. $280obo for the set. Cam looks brand new with NO wear marks at all.
http://www.summitracing.com/parts/cca-12-467-8
SOLD==Comp Ultra Pro Mag Roller Rocker Arms, roller hydraulic lifters.
==383 stroker short block(sbc, small block chevy), I need to pull the oil pan to be sure of the brands for each part but I believe they are SRP pistons, Scat crank, 6" Eagle rods. short block has about 10,000 miles on it, it was built by Kilpaticks in Waukesha WI. It has developed a very slight knock when warm (no sounds when cold). I'm sure you could freshen up the block with bearings and rings and it would be like new. $550obo
Old Jul 5, 2013 | 10:24 PM
SMKNGTA's Avatar
Car: 1989 GTA
Re: T56 6 speed swap, AFR Heads, Holley Stealthram, Mufflex Magnaflow, 383
Lots of interest, parts are still available
Old Jul 6, 2013 | 12:00 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Gah. If only the HSR was for vortec's
Old Jul 6, 2013 | 08:01 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
interested in the 4" catback
Old Jul 6, 2013 | 11:34 PM
SMKNGTA's Avatar
Car: 1989 GTA
Justin89formy- nice talkin to you, looks like your going to have one heck of a setup when the blower is on
aiarchon- i can help you solve that problem and just sell you the AFR heads that will work with the Stealthram
Old Jul 7, 2013 | 08:17 AM
Gary Anderson's Avatar
Any idea what the trans is out of, gear ratios or a tag number? Thanks.
Old Jul 7, 2013 | 09:27 AM
Car: 86' IROC
Axle/Gears: 3.45
I wish I could swing it! GLWS!
Old Jul 7, 2013 | 09:38 AM
SMKNGTA's Avatar
Car: 1989 GTA
I believe the trans came from a 95 or 96 Z28, I can get a tag number later to confirm.
Old Jul 7, 2013 | 10:01 PM
SMKNGTA's Avatar
Car: 1989 GTA
There looks to be a factory sticker on the top of the trans but the numbers are worn off, this number was on the side of the case 13-86-065-902 though.
Old Jul 7, 2013 | 11:22 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
I'm potentially interested in that shortblock if you're willing to ship it (headache, I know). Just get back to me whenever you verify the part numbers and have pictures of the shortblock.
Old Jul 8, 2013 | 04:35 PM
SMKNGTA's Avatar
Car: 1989 GTA
DeltaElite121- Yeah that would be a pain to ship, I'll let you know though when I get the pan off.
SMKNGTA's Avatar
Car: 1989 GTA
Hawks t56 crossmember is SOLD.
Old Jul 8, 2013 | 11:18 PM
Car: 89 formula 350
money sent for mufflex exhaust!
Old Jul 9, 2013 | 07:39 AM
SMKNGTA's Avatar
Car: 1989 GTA
Thanks Justin89formy.
Mufflex Exhaust is Sold
Headers and Y-pipe are still available.
Old Jul 10, 2013 | 11:17 AM
SMKNGTA's Avatar
Car: 1989 GTA
T56 Swap is SOLD
Clutch parts are SOLD
Old Jul 12, 2013 | 11:18 PM
SMKNGTA's Avatar
Car: 1989 GTA
AFR195 heads, roller rockers and lifters are SOLD
Old Jul 13, 2013 | 12:47 AM
indebt's Avatar
Pm sent
Old Jul 13, 2013 | 09:09 PM
Juan_Garza's Avatar
Car: 91 Firebird convertible
Engine: 350 tpi
Transmission: 700 r4
Axle/Gears: 3.73's
Still got the stealth ram, if you do how much shipped to 78516
Old Jul 13, 2013 | 09:12 PM
Juan_Garza's Avatar
Engine: 350 tpi
Axle/Gears: 3.73's
Injectors included
Old Jul 14, 2013 | 12:40 AM
SMKNGTA's Avatar
Car: 1989 GTA
I do have the stealthram, injectors are not included. I do have a set of 24lb Holley injectors that maybe we could make a deal with. I will check on the shipping Monday for you.
Old Jul 15, 2013 | 02:07 PM
SMKNGTA's Avatar
Car: 1989 GTA
Juan_Garza sent PM
Old Jul 16, 2013 | 12:09 PM
SMKNGTA's Avatar
Car: 1989 GTA
Dougs Headers and Y-pipe are SOLD.
Old Jul 17, 2013 | 09:16 PM
SMKNGTA's Avatar
Car: 1989 GTA
Stealthram setup is SOLD
Still have the 280XFI cam and pushrods, and the 383 shortblock.
Old Nov 16, 2014 | 11:05 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
PM'd
InfinityShade
Aug 22, 2015 08:00 PM
89mulletbird
Aug 12, 2015 07:08 PM
BBSDesigns
Aug 11, 2015 07:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
