[CO] Tpi , Tbi reprograming and memcals/proms
Old Oct 8, 2013 | 04:32 AM
  #51
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tpi , Tbi reprograming and memcals/proms
Live Dyno tuning is allways the best, but if you want to get real close you can send me datalogs to tune off of or if you sold in a moates.net g2 and buy a burn2 using a newer flash based eeprom I'm willing to work a deal to make changes to your tune and email it for you to burn.
Old Oct 12, 2013 | 08:06 PM
  #52
Engine: Lb9
Transmission: M20
Weekly bump, I'm on dialup until Wednesday night. please be patient for pm and email replies
Old Oct 21, 2013 | 10:04 PM
  #53
Engine: Lb9
Transmission: M20
bump
Old Oct 22, 2013 | 08:28 AM
  #54
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Do you have any maps preset for an L98/Vortec heads/SDPC intake/LT4 Cam ? In the middle of this swap, and I figured programming would be my stumbling block
Old Oct 22, 2013 | 04:59 PM
  #55
Engine: Lb9
Transmission: M20
Sorry, I have worked up a good timing table for the l31 heads but have only worked with the lt4 hot cam with speed density. I would be more than happy to work with you off data logs.
Old Oct 30, 2013 | 02:38 AM
  #56
Engine: Lb9
Transmission: M20
bump bump bump
Old Nov 1, 2013 | 08:27 PM
  #57
87irocZ28Crush's Avatar
Car: 1987 Iroc Z28
Pm sent. Free bump.
Old Nov 30, 2013 | 07:27 PM
  #58
tunedportz51's Avatar
I have a 85 L98 4+3, Edelbrock RPM heads, Comp XE262H14 flat tappet, 1.6 rockers, Hi-Flo manifold, fully siamesed stock runners, 52mm throttle body and 24 pound Bosch 3's. My 870 ECM already has the adapter. Datalogging sucks. Doable? quote?
Old Dec 2, 2013 | 08:16 PM
  #59
Engine: Lb9
Transmission: M20
If you can send my datalogs with tuner pro I can assist with the tuning. I'm not a real fan of the 1f 870 slow baud.
Old Dec 2, 2013 | 08:56 PM
  #60
310cid's Avatar
Car: 92 camaro
Engine: 406
How much do u charge for a street tune on a custom set up prom
Old Dec 2, 2013 | 09:34 PM
  #61
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
this guy is good, we did a TBI to TPI with ECU conversion in a pickup, it lit right --- off ---- well---sort of LOL er after I got the wiring RIGHT ( I R Mart ) it runs smooth and strong thanks man!
Old Dec 3, 2013 | 06:38 AM
  #62
Engine: Lb9
Transmission: M20
I need to update my flyer, I like to start with the closest calibration first change injector size if needed, disable malfunction codes if needed and emissions if desired for $65 . Then based off a datalog emailed to me for $40 each additional tune I will fine tune. If anyone wants to work with me and have me do the tuning and they burn the calibration I'm willing to work out a deal there too. It depends on how much time is involved but I'm very fair in pricing
Old Dec 3, 2013 | 06:40 AM
  #63
Engine: Lb9
Transmission: M20
Old Dec 3, 2013 | 07:15 PM
  #64
944nate's Avatar
Want a title? Post!
I have a 91 Z28 L98,converted to 5 speed by previous owner runs rich with a slight idle problem, it currently has a small comp cam , headers , bbk twin 50 or 54 mm tb, air pump removed , cats removed. The car runs strong but i can tell somethings holding it back. It also has a slight stumble on acceleration. In the future i would like to upgrade injectors,fuel pump and maybe ported upper and siamesed runners. Should i try to reprogram now? or wait as i do drive this car about twice a week cause its fun!
Old Dec 4, 2013 | 08:39 AM
  #65
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
+1
I had him reprogram a prom for my 1988 Formula 350 with some minor performance twinks and the 9th injector delete. Very happy with the results, fast turn around. If you want some ECM tuning done, I highly recommend him.
Old Dec 4, 2013 | 12:57 PM
  #66
Engine: Lb9
Transmission: M20
I think the best thing to do is to figure out if it is the injectors causing the stumble, tps, cts, bad map or dead or lazy o2. If it has the factory multec injectors start there and give southbay a call and get some bosch 3 22#hr injectors. getting tuner pro rt and a aldl to USB cable is a real valuable tool. Feel free to send me a pm and I will be more than happy to try to help you figure out what's going on and get your engine to run better
Old Dec 4, 2013 | 12:59 PM
  #67
Engine: Lb9
Transmission: M20
Originally Posted by lonestar7
+1
I really appreciate the feedback, I pride myself in being honest and fair priced
Old Dec 4, 2013 | 05:13 PM
  #68
944nate's Avatar
Want a title? Post!
Sounds like a good start,could any of the problem be that it has never been reprogrammed to 5 spd?
Old Dec 4, 2013 | 05:18 PM
  #69
Engine: Lb9
Transmission: M20
The only issues I have I have seen with a automatic tune with a manual transmission is slight bucking on deceleration.
Old Dec 16, 2013 | 02:57 AM
  #70
Engine: Lb9
Transmission: M20
Bump
Old Dec 16, 2013 | 11:30 AM
  #71
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
I am planning on doing some upgrades to my 305 tpi motor, can you message me so we can discuss what route to go.
Old Dec 16, 2013 | 12:43 PM
  #72
Engine: Lb9
Transmission: M20
Pm sent
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
