Complete 388 stroker. Turbo 350 converter
Car: 91 RS
Engine: 421 18 degree sbc.
Transmission: 2 speed glide from tci
Axle/Gears: 9" ford 5.29 gears
I have a turbo 350 3500 stall converter only 20 passes since new over 400$ new ill take 250$ plus shipping.
The engine is complete intake to oil pan with distributor and Taylor plug wires. Like the title says its a complete 388 stroker pump gas motor. Made 410hp with 750 gas carb at 5500rpm. The internals are as followed.
Heads: factory cast 882 number heads ported and polished with valve job. Complete with dual springs and comp magnum 1.6 rockers. Has aluminum fab valve covers and breathers in both covers.
Intake is a Holley strip dominator. Ported to match the ports on heads. Very nice street strip intake with good rpm range.
The cam is a isky hydraulic roller. Comp lifters with comp push rods.
Factory rods with arp bolts clevite bearings throughout.
Speed pro flat top pistons making compression a 10:1 ratio.
Scat cast crank. Stock oil pump with high pressure spring.
Always ran valvoline vr1 racing oil and purolator filter.
Very few street miles has seen some track time. Best pass was 7.24 at 98mph in a 3,300lb car. Asking 2200 for motor plus freight to ship. You definitely can't build it for this price.
Car: 91 RS
Re: Complete 388 stroker. Turbo 350 converter
Need this stuff gone may do some trading.
Terrell351
Jun 13, 2021 01:13 PM
