[IL] New NOS Super Powershot Nitrous Kit, Edelbrock Heads, Comp Cam, MSD Distrib,Tons More
Up for sale is a NOS super powershot nitrous kit. The NOS super powershot nitrous kit itself is adjustable from 100-150 HP and can be upgraded just by changing the solenoid to a bigger shot if needed. The bottle has also been fitted with an NHRA/ISRA approved blow off valve. I also have an NOS low fuel pressure shut off switch, and a jeg's billet carb mounted activation switch (other items in the photo have been sold)
The NOS setup goes for over $600 from the speed shops, and I will take $525
$25 for the fuel pressure safety valve
$25 for the billet carb mount activation switch
Edelbrock E series 210cc aluminum cylinder heads (these are a step above the RPM's and below a victor) for small block chevy. The package includes everything you need from the heads, massive 2.08/1.60 stainless steel swirl polished valves, screw in rocker studs, viton valve seals, guide plates, springs, locks, keepers, spring seats,...etc. All is brand new in the box and ready to go! $1,000 takes everything.
New comp cams extreme energy 274 cam and lifter set (230/236 .490/.490) Will take only $175. Sells for $211.90 with shipping from Summit.
MSD pro billet distributor with MSD 8.5 superconductor wires NIB, $285
Total seal plasma moly piston rings for +.030 400 NIB $100
Edelbrock billet electric fuel pump, 6.5 PSI with 120 gallon flow NIB $180
Profile piston ring filer, NIB $45
Scat "Pro-Comp" 6" I-beam rods NIB $320
4 piece taylor wire set $10
Sears power drill $20
MSD hei to hei plug style coil wire $8
Chrome alternator bracket X2 $15
Chrome radiator hose neck $5
Dwell/points/tach meter $25
Hard to find reclining seat bar $65
Chrome distributor hold down $5
Chrome fuel pump block off plate $7
4 piece new in the package keystone offset washers for GM cars $7
70-81 firebird glove box door $20
re-pop battery tray with holddown $15
Chrome timing pointer with adjustable pointer for small block $5 - Sold
New set of 4 axle u bolts with hardware, $25
New pair of Fel-pro 1004 head gaskets with the brodix mods to allow them to be used on 400's without having to drill steam holes in the heads, $70
2 new pairs of 7/8" sway bar bushings, $8 a pair
New set of 4 Moog upper control arm bushings, $30
LT1Formula
Aug 20, 2015 09:36 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
