[NJ] New: Trick Flow 195cc Heads + Rockers $800
Car: 1994 Z28
Engine: 355 LT1
Small block chevy, perimeter valve cover trick flow heads. 195cc intake runners, 62cc combustion chambers. Equip with 1.470" springs (120@1.78", 300@1.28, 360lbs/inch) .540" max lift and a set of Comp Cams cast aluminum 1.5 roller rockers, guide plates and rocker studs.
Casting on heads are TF8-8BC-3 another number is 32721-2.
Part number is TFS-30400002. Sell for $1,149.97 on summit. Rockers are 17001-16, sell for $159.67.
Heads were bolted onto a motor and never fired (nor were they ever introduced to any oil). They are in perfect condition.
$800 plus shipping... paid $1,300 for this setup. Prefer to be contacted via email zraffz@gmail.com.
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Re: New: Trick Flow 195cc Heads + Rockers $800
Willing to sell the rockers separat?
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
