[PA] High performance part out
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Everything has less then 750 miles
Engine:
1500$ for long block
4bolt main block
Eagle 383 rotating assembly
Edelbrock E-tec 210 heads
TPIS MiniRam 1206 port - 1000 with fuel rails and injectors and waterneck
Holley HP EFI - 1000 for everything - Spoken for
Holley 36lbs injectors 522-368 - $275
Holley Duel 58mm T-Body 112-503 - $300
Dyno-Don headers no AIR, w/Y-pipe 500$
Borla Catback
CompCam XE294H-10
GM performance front end accessory kit
MSD 8366 Distributor Spoken for
Taylor 409 wires Spoken for
MSD blaster coil Spoken for
3-Core Aluminum Radiator
MSD 6AL2 Spoken for
Canton Road Race Oil Pan 15-244 - $225
SLP Line Lock 24048 - $100
March Underdrive pulleys 4410 - $125
Tuff Stuff high flow chrome water pump - $100
Melling Select High flow oil pump
Will do package deals
Transmission 700R4;
2000$ with convertor
Yank SS3600 lockup convertor - $625
Complete Raybestos Stage One Friction Kit with 3-4 Kolene steels
Replaced all seals and gaskets
Wide Raybestos Pro Series Band
Re-manufactured forward sprag assembly with updated 29 element sprag
New ACDelco reverse input drum
"Beast" sun shell
ACDelco 5 pinion rear planetary gear
Corvette governor
ACDelco governor cover
Steel chrome pan with drain plug
One wire TCC lock-up switch
.500 boost valve
3-4 upshift kit
ACDelco accumulator pistons
Sonnex 2nd gear "Super Hold" servo
Shift technology 4th gear "Super hold" servo with billet cover
Suspension;
UMI K-member Item#2401 $450
UMI front A-arms Item#2031 $400
UMI transmission crossmember with torque arm relocator
UMI torque arm Item #2217 $350
KYB AGX shocks all around - $300
Founders Performance upper shock mounts - 125$
Founders Performance rear lower control arms - $40
Founders Performance single adjustable panhard bar sold
New/Reman ACDelco quick ratio steering box -80$
Jeep steering shaft - $30
Made in USA steering components
UMI tie-rod adjusters
Steering components - $100
Eibach Pro-kit springs - $180
17x9 Repro ZR1 wheels
Nitto NT05 Drag Radials in back
Falken Tires is front
Wheels and tires - $950
9 Bolt rear, 3.27 gears, Posi works. Rear Disk brakes
Make offers. I won't ship big parts. Wont break apart till motor and trans is sold.
Underside picture is before the Canton Road Racing pan
Engine:
4bolt main block
Borla Catback
CompCam XE294H-10
MSD 6AL2 Spoken for
Transmission 700R4;
"Beast" sun shell
Corvette governor
.500 boost valve
3-4 upshift kit
Suspension;
Car: 88 Firebird.
Engine: 383 HSR
Re: High performance part out
350$, but I don't want to immobilize the car until the motor and trans is sold
Car: 88 Firebird.
Engine: 383 HSR
I'd ship the shocks and springs. I'm outside of philly, on the east side of PA.
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
How much for the following items? I understand you don't want to take it off til car motor and trans is sold.
[quote=Killert;5632785]I'd ship the shocks and springs. I'm outside of philly, on the east side of PA.[/qu
Im interested in the k member and a arms. Located in WV so I could arrange pick up. How much u asking?
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
How much for the panhard bar plus shipping to 78415?
Car: 88 Firebird.
Engine: 383 HSR
Car: 88 Firebird.
Engine: 383 HSR
Wont ship.
Springs are spoken for.
Rims and tires, 1250$ R/F wheel has some rash. Tires have less then 500miles. Won't ship.
Car: 88 Firebird.
Engine: 383 HSR
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Tell me about the Dyno Don headers:
Coated?
1.75"?.. I think that is the only size.
AIR tubes?
Any dents, dings, scratches? Especially if "clearanced" about frame, steering, etc.
Y pipe?
Shipping to 80401?
Thanks,
Joe
Coated?
AIR tubes?
Y pipe?
Shipping to 80401?
Thanks,
Joe
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Engine:
2000$ for long block
4bolt main block
TPIS MiniRam 1206 port - 1200 with fuel rails and injectors
36Lb injectors
Dyno-Don headers
Borla Catback
CompCam XE294H-10
Taylor 409 wires
MSD blaster coil
Battery relocated to the truck
MSD 6AL2
SLP Line Lock
Transmission 700R4;
"Beast" sun shell
Corvette governor
.500 boost valve
3-4 upshift kit
Suspension;
UMI K-member Spoken for
UMI front A-arms Spoken for
UMI torque arm
KYB AGX shocks all around Spoken for
Founders Performance upper shock mounts Spoken for
Founders Performance rear lower control arms Spoken for
Jeep steering shaft
MOOG steering components
Eibach Pro-kit springs Spoken for
Engine:
4bolt main block
36Lb injectors
Dyno-Don headers
Borla Catback
CompCam XE294H-10
Taylor 409 wires
MSD blaster coil
MSD 6AL2
SLP Line Lock
Transmission 700R4;
"Beast" sun shell
Corvette governor
.500 boost valve
3-4 upshift kit
Suspension;
UMI torque arm
Jeep steering shaft
I Must ask why?
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Interested in trans crossmember with torque arm relocation? Which trans does it fit? Part number or something?
Car: 88 Firebird.
Engine: 383 HSR
Car: 88 Firebird.
Engine: 383 HSR
Theres a bunch of numbers its basically
http://www.holley.com/550-601.asp
with 36lb injectors and some extras
I had it controlling fuel pump, both cooling fans and TCC
Was set up for the HSR I ran, then changed to a MiniRam
Holley EFI is spoken for now.
IT's for the 700r4 thats in the car. No shipping.
http://umiperformance.com/catalog/in...roducts_id=131
ITs black
ITs black
Car: 88 Firebird.
Engine: 383 HSR
No clearancing of any kind. But the Ceramic coating was greyed due to improper timing. No AIR tubes. 1.75in. Will come with the Stage 8 locking bolts. Won't ship.
Car: 1987 Trans AM
Engine: 355 4-bolt, L98 heads, Holley 650DP
Axle/Gears: 3.70 9-bolt
How much are you looking for the exhaust? Are you willing to sell just the short block?
Car: 88 Firebird.
Engine: 383 HSR
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
how much for the umi sleeves and jeep shaft shipped to 90247
How much hp will the tranny take. Need someting that will take ~600rwhp. If so, who built it and any warranty? If it can get the job done, I'd want it, trans x-mbr and torque arm and maybe headers if they are still nice. also is the Yank lockup or not? would be a long drive from ALA..though.
looking more closely... lineloc and maybe radiator
Robby
Robby
Car: 86 Camaro, IROC springs & bars
Engine: Mild 350,Q-jet,headers
Transmission: M-21, 12#flywheel
Axle/Gears: 98 7.5, 3.73 torsen.
Also interested in the oil pan, pump & pickup.
Car: 88 Firebird.
Engine: 383 HSR
TA8487
Aug 16, 2015 12:21 PM
