[WV] FS-NEW GM serpentine acces. belt drive system with a/c
1 Post
Car: 86 2wd
Axle/Gears: 2:73 open (for now)
I bought a GMPP 385 Fast Burn turn key crate motor and am not using this. This is a complete kit that is all new in the boxes. GM part number is 12497698. Feel free to look it up. Sells for $900 at Summit, i'll sell for $420. Rather not do paypal but will if you pay the 3% fee
comes with new a/c compressor, new power steering pump, new alternator, new water pump, all new brackets and pulleys etc....copied and pasted from paceparts web site-
here's link to it on summit-
http://www.summitracing.com/parts/na...7698/overview/
This deluxe serpentine belt drive system with air conditioner includes all the components to install on small-block Chevrolet engines. The bolts, nuts, spacers and braces are included with the following major items:
10055800 Secondary Air Injector pump bracket
88964863 Air compressor assembly, (CR4)
10129569 Idler belt pulley bracket
88894005 Water pump kit
10055880 Water pump pulley
10055879 Crankshaft pulley
10463172 Generator assembly (reman.)
12117361 Generator connector (with lead)
10055798 Drive Belt Tensioner Assembly
88986814 2,470 MM Belt (fan, water pump, A/C pump, and generator)
10105212 Generator & power steering bracket
88985115 Power steering pump
14102096 Power steering pulley
Note: Due to clearance issues, this Accessory Drive Kit is not recommended for Corvettes and All sales are final.
1992 Trans Am
05-10-2023 07:19 PM
evilstuie
01-09-2020 08:29 PM
db057
08-11-2015 10:11 PM
