Richmond 3.73 gears for series 2 carrier
Old Dec 15, 2013 | 05:12 AM
Kyle86's Avatar
Car: 86 Camaro IROC-Z28
Engine: 4.8 LS 68mm turbo
Transmission: Turbo 350
Axle/Gears: 3.08 10 bolt
Used gears, nothing is wrong with them and they worked great. Even a couple 1.7x passes on them. $100 shipped
Old Jan 2, 2014 | 09:50 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: Richmond 3.73 gears for 7.5 or 7.625 rear axle
OBO?
Old Jan 2, 2014 | 10:55 PM
Kyle86's Avatar
Whatcha got?
Old Jan 2, 2014 | 11:18 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
which series carrier? part number?
Old Jan 3, 2014 | 03:53 PM
Kyle86's Avatar
Sorry these are the THICK gears for series 2 carrier. So if you have 2.73s these are direct replacement on that carrier.
Old Jan 5, 2014 | 05:58 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Richmond 3.73 gears for series 2 carrier
did you see what the pattern looked like before you pulled them out? did they whine?
Old Jan 5, 2014 | 06:40 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
They are Richmond gears, 99.9% of them make noise.
Old Jan 5, 2014 | 07:41 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
I was meaning outside the norm for aftermarket gears.
these would be going in my s-10 as the current rear was overloaded so the housing is a tad bent and now my pinion has slight movement and im preparing incase the current gears are bad from the movement.im strongly thinking the bent housing is causing angle issues and vibrations which killed the current setup.
current setup is a 3 series carrier, spare housing is a 2 series.
Old Jan 5, 2014 | 11:26 PM
kitt462d's Avatar
Car: 1985 TA
Engine: 350 Carb
How do you know which carrier you have? I have my stock rear in my 1985 305 700r4 TA, and I have 1 1999 firebird rear to go in someday. Would love these gears if they would fit and haven't been sold yet. Thanks for any help.
Old Jan 7, 2014 | 07:40 PM
Kyle86's Avatar
The pattern was great. I was there when my transmission guy set them up. The pattern was centered up correctly. They did not make any noise outside the norm for used gears. They look fine, only reason I pulled them was to swap in some 3.08s for my turbo car.
Stock carriers = gears used in them
Series 2 carrier = 2.73 - 3.08
Series 3 carrier = 3.23 - 4.56
Old Jan 8, 2014 | 10:35 PM
Brichards79's Avatar
Car: 1989 camaro rs
Engine: lo5
Axle/Gears: 373 with detroit limited slip
80 dollars shipped if u still have the gear set
Old Jan 13, 2014 | 11:49 AM
1983cameroman's Avatar
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
still have gears
Old Jan 14, 2014 | 03:15 AM
Kyle86's Avatar
Sale pending
Old Jan 17, 2014 | 09:11 PM
Kyle86's Avatar
Still have gears for sale.
Kyle86's Avatar
$80 shipped
Old Jan 29, 2014 | 02:00 PM
Kyle86's Avatar
Bump pics added up top
Old Jan 29, 2014 | 03:42 PM
tartagliaz28's Avatar
Car: 2013 ZL1 convertible
Engine: 6.2 supercharged
Transmission: 6l90e
sold. payment sent thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
