[OH] 355 HSR/700r4 combo
Old Feb 2, 2014 | 01:37 PM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
355 HSR/700r4 combo
I'm selling my complete engine and tranny setup. Here are the details.
355 L98 - 5000 miles. - $500
all clearances checked, rebuilt with new crank, rod, and cam bearings, hyper pistons and rings. The crank was ground and polished.
10.5:1 compression
lt4 hotcam .525/.525 224/224
holley stealthram - $700
- kirban performance billet aluminum adjustable fuel pressure regulator
- stock 48mm TB with airfoil
- fuel pressure gauge mounted to the rails
- Braided stainless lines to run to the stock hard lines (you have to buy two fittings for the stock fuel lines)
- no fuel injectors
- new set of felpro 1205 intake gaskets
113 aluminum vette heads - $800 ($950 with the rockers)
- 18 hours of porting and polishing
- 2.02/1.56 valves machined in
- manley titanium race valves with 7 angle valve job
- zz9 springs good to .550 lift
- screw in studs with pushrod guide plates
- 1.6 full roller rockers
march serpentine system with underdrive pullies. - $300
Hooker super competition long tube headers, jet hot coated (**** poor coating if you ask me) with custom 3 inch y pipe. They have some rust and scratches but work awesome - $600
700r4 tranny - SOLD
- phoenix racing 2500 stall torque converter
- transgo shift kit
- corvette servo and .500 boost valve
90 speed density ecm and 87 custom wiring harness - $150
- already has the prom adapter to throw on your own chips
- setup for no AC, no smog
- converted to heated o2, 90+ style relays
- the fans run in parallel from the computer, when one fan comes on they both come on
Summit racing high torque mini starter - 100$
stock 87 tpi small cap distributor with new gear, pickup, ICM, has msd cap and button - 100$
I will upload pictures in the next day or two when I get everything cleaned up. Everything is out of the car and ready to be pulled apart.
Old Feb 3, 2014 | 06:08 PM
Jose Zuñiga's Avatar
Re: 355 HSR/700r4 combo
Do you are sure this tranny can handle the power of that engine?
Old Feb 3, 2014 | 07:22 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Nice setup you have for sale.If someone is looking to upgrade their stock Camaro this would be an excellent buy.
Old Feb 6, 2014 | 05:58 PM
CashMunson's Avatar
Engine: 408 LS
I honestly don't know, it has so far. It might not last if I was launching at 4k rpm with slicks.
Old Feb 7, 2014 | 11:24 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Let me know if u will part out im looking 4 a HSR complete and roller rockers
Old Feb 10, 2014 | 07:35 AM
Thanks for reply.
I asked because I have a similar engine but my 700r4 is stock, so I'm looking whats parts have to buy for build my trans ready for handle like 380 rwhp.
Old Feb 15, 2014 | 12:38 PM
CashMunson's Avatar
Engine: 408 LS
Here are some pictures of the engine sitting in the car still.
Attached Thumbnails 355 HSR/700r4 combo-008.jpg   355 HSR/700r4 combo-009.jpg   355 HSR/700r4 combo-011.jpg
Old Feb 17, 2014 | 07:55 AM
bta4me's Avatar
Car: 1988 gta
Engine: 5.7
Would u sell just trans
Old Feb 18, 2014 | 11:10 AM
CashMunson's Avatar
Engine: 408 LS
I will if I can find somebody to buy just the engine.
Old Mar 1, 2014 | 11:55 AM
Ymesss's Avatar
Car: 1986 Camaro Z-28
If you were interested in selling the car as well, i'm looking for something complete... not far from Ravenna
Old Mar 2, 2014 | 09:59 AM
CashMunson's Avatar
Engine: 408 LS
Sorry I plan to keep the car. I have decided to just part everything out. It's a smoking deal as a whole package, but nobody ever had cash in hand.
Old Mar 2, 2014 | 10:29 AM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
If you decide to part out I would like to get inline for the intake.
Old Mar 4, 2014 | 10:01 PM
maradits's Avatar
Want a title? Post!
I might be interested in the long block and intake (no headers, ecu, trans, etc) for the right price
Old Mar 5, 2014 | 09:12 PM
CashMunson's Avatar
Engine: 408 LS
pm sent
Old Mar 6, 2014 | 03:38 PM
CashMunson's Avatar
Engine: 408 LS
I am definitely parting everything out. Are you still interested in the hsr? I'm selling the hsr complete except for the injectors.
Old Mar 9, 2014 | 10:21 AM
CashMunson's Avatar
Engine: 408 LS
Updated this with prices for everything
Old Mar 10, 2014 | 10:59 PM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
Just bought a 383 and need a HSR set-up (already have 30lb injectors)-this has regular alum. heads on it. 383 is (atk from summit), is your HSR made for this style? I am interested in it if it is.
Old Mar 11, 2014 | 01:34 PM
CashMunson's Avatar
Engine: 408 LS
As far as I know it will bolt right up, the 383 you bought is most likely a roller block. Which 383 did you buy?
Old Mar 11, 2014 | 07:22 PM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
I bought a roller block from summit. It is the HP36 (atk brand). 425 hp and 465 tq (I think w\out looking at paperwork). Gen 1 4bolt 1pc RMS. They are not specific on the heads, I've seen them with dart, edelbrock, and some other brand of aluminum head on this specific engine. I have been waiting to find out specifically which head it will be, but haven't heard from them yet, nor has the engine showed up yet, but I want a HSR set up on this, just haven't bought one yet because of not knowing which style to get.
Old Mar 11, 2014 | 10:01 PM
CashMunson's Avatar
Engine: 408 LS
Unless the heads are vortec heads, my hsr will bolt up. If you get vortec heads with the new motor then you'll have to run the vortec hsr.
Old Mar 18, 2014 | 07:18 PM
CashMunson's Avatar
Engine: 408 LS
2800 for everything, need this stuff gone.
Old Mar 19, 2014 | 01:09 PM
Sojer's Avatar
HSR priced to high pm me if u want a sale I just need intake no TB no gaskets
Old Mar 19, 2014 | 06:10 PM
CashMunson's Avatar
Engine: 408 LS
It might seem a little high to the average person, but you aren't getting just an hsr. Most people are selling just the intake by itself for 400-500 dollars. I spent 120 on the AFPR, another 140 on the braided stainless lines with all the fittings, 40 for the liquid filled FP gauge. My hsr is also milled 3/16 inch off the runners so it will fit under a pontiac hood. It also has tapped holes with fittings on the back of the intake to run the vacuum lines.
Remember you can't use your stock tpi fuel lines to hook an hsr up, you have to make your own. Mine comes with everything you need to bolt it right to the factory hard lines.
Old Mar 23, 2014 | 04:14 PM
CashMunson's Avatar
Engine: 408 LS
Tranny is sold.
Old Mar 27, 2014 | 03:35 PM
CashMunson's Avatar
Engine: 408 LS
bump to the top. 2500 for everything.
Old Apr 1, 2014 | 04:31 PM
CashMunson's Avatar
Engine: 408 LS
Make offers, need this stuff gone.
Old Apr 1, 2014 | 04:43 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Man if you were closer id scoop up that 355 block, bump for you!
Old Apr 5, 2014 | 11:41 AM
CashMunson's Avatar
Engine: 408 LS
weekend bump. Somebody make an offer on some of this stuff. If you want pictures of something let me know and i will get them.
Old Apr 16, 2014 | 04:54 PM
CashMunson's Avatar
Engine: 408 LS
to the top
Old Apr 16, 2014 | 10:04 PM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
Transmission: automatic
I need a ECM!!
Old Apr 17, 2014 | 09:44 AM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Cash , I remember you from the old ne3g days. How far are you from Parkersburg?
Interested in the 355
Old Apr 17, 2014 | 04:56 PM
CashMunson's Avatar
Engine: 408 LS
pm sent
Old Apr 24, 2014 | 05:08 PM
CashMunson's Avatar
Engine: 408 LS
bump, still for sale
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
anesthes
Sep 18, 2015 12:34 PM
