[CA] Magnaflow Cataytic converter direct fit
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
Used for 500 miles on great running car, direct fit, comes with flange. NOT ca approved, 49 state. Did pass smog in ca with this cat. took off only due to swapping to a LT1 engine. Has 2 1/2 inlet and outlet for 2 1/2 y pipes usually found on V6, 305 rs, some z28s and irocs (measure your y pipe) also have the clamp for the slip fit end. hardware included. Cat is stainless steel and cosmetically in perfect shape, as is the insides, not melted, cracked or loose. i paid 150 for it. will sell $$$$$40+ shipping obo. Willing to negotiate or trade for parts i may need. Pm me i can get back to you in 1 day.nd or i can pm your my cell #. also have stock lt1 manifolds in good shape that are 93-94 that will work in a third gen. comes with gaskets. I am located 30 minutes north of los angeles
Brendan Ryan
Brendan Ryan
Dialed_In
Aug 20, 2015 01:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
