[CA] Corvette L98 and 700R4
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Corvette L98 motor converted for F-body.
Easy swap into any F-Body car. The L98 is from a '91 Corvette and had 22k on it when I bought it. I put a little less than 30k miles on it so it has less than 53k miles. The 700R4 was completely rebuilt with all the good parts and a Trans-Go shift kit was installed at the same time. Trans has less than 2,500 miles on it. The car has not been driven or started for over 8 years but has been garaged during that time. I've turned the crank a few times so I know it is still in good condition, nothing frozen. The motor and trans is still in the car.
I'll sell the motor and trans for $1,200.00
$1,000.00 if you take the whole car.
I'm located in Arcadia, CA
No shipping available must be able to tow it home.
Anyone interested please PM me.
Car: 1992 Formula 350
Engine: 5.7 L98
Re: Corvette L98 and 700R4
Does the engine have the distributor from the 91 vette? If so how did you merge it withe external coils?
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
I used an aftermarket HEI and coil. I do have the original GM HEI Coil in cap distributor for sale if your interested.
Car: 1988 IROC Z coupe
Engine: stock LB9...for now.
Transmission: T5 non world class :(
Axle/Gears: BW with 3.73 gears.
Do you still have this?
Do you have the vin engine prefix code?
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
