[CO] Theoretical - What should I ask for my 9-bolt?
Old May 1, 2014 | 04:28 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Giving some thought to possibly upgrading from my 9-bolt to a MW 9" with a quick-change. But if I do, I'll more than likely sell the differential that I have now so that I can make up part of the cost. Here's the info:
  • Borg-Warner Aussie 9-bolt;
  • Positraction;
  • 3:27:1 gearset;
  • TA Performance differential cover (with bearing supports);
  • Redline gear oil with GM friction modifier added;
I've also sandblasted it & painted it with a POR-15 equivalent paint (flat black), so it looks halfway decent.
I'm guessing that I'll need to (want to?) keep the disc-brake backing plates & other brake parts to transfer over to the new rearend (right?), so none of that would be included.
BTW, given the thing's weight, I really do NOT want to try to ship it, I'm hoping that I'll be able to sell it locally.
Thanks for reading guys, please let me know what you think.
Old May 1, 2014 | 04:34 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Re: Theoretical - What should I ask for my 9-bolt?
Isn't it illegal to ship it full of fluid? Wouldn't that be considered transporting Hazmat? If you ship it.
Old May 1, 2014 | 05:39 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
  • Positraction;
  • 3:27:1 gearset;
Whats shape are the posi cones in? If the rear posi works and is in good shape, maybe $350-$450. I'm not sure you can swap the brake parts on a different rear. There isn't too big of a demand for a 9 bolt rear any more, maybe you would get more parting it out?
Old May 1, 2014 | 09:27 PM
V8Rumble's Avatar
Veaceonee - I don't plan on shipping it, so that's a non-factor.
red rock - Thanks for the reply. The last time that I drove the car, everything related to the rear end was in GREAT shape, the only reason for the Red Line gear oil was because I swapped the differential cover for the TA Performance unit. If I need to, I'm completely comfortable using the 9-bolt for another 50,000 miles or so (the car had only about 89,000 miles when I parked it).
And I'm not entirely sure about swapping the brake parts, but I seem to recall reading fairly frequently about people doing that... If it's necessary to swap to new brakes on the rear when upgrading, then how would you know that the stock prop valve would work with the new parts?? (Actually, that's a question that I already have, since I've swapped to 13" Baer brakes on the front, so I'll probably need to re-do the prop valve anyway...)
Old May 1, 2014 | 09:36 PM
red rock's Avatar
Car: 1987 iroc
I don't know, but if your willing to keep the 9 bolt, you could rebuild the carrier and run a 3.70 gear. The 9 bolt is a pretty strong rear. I have built and rebuilt a couple and bought new posi cones from http://9bolt.com/
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
6speedIROC
Sep 13, 2015 01:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
TrueBlue91RS
Car Audio
Oct 12, 2001 07:05 AM
