[AZ] 7165 stock ECM with 1987 engine and dash harness
I have a 7165 complete ECM out of a TPI. I was told 350. Comes with the engine harness and the harness from under the dash. I had planned on using this then decided to change to a 7730 and use my existing harness
When I got it I was told it was out of an '87 automatic
$200 shipped to lower 48 states.
can be payed with paypal or CC
Located in Phx AZ
Located in Phx AZ
Car: 89 trans am GTA
Engine: 355
Re: 7165 stock ECM with 1987 engine and dash harness
if you are willing to separate im looking for a smoking deal on that ecm. i dont need the prom just the ecm as long as its good.
I got this whole setup through a friend of a friend. I was told it was working when pulled. I do not know the working condition of the ECM I assume it it's good.
make me an offer without the prom. JUST the ECM.
$60 shipped for the under dash harness (I still have to post up a pic of it) will do that tonight.
$50 shipped for the 7165 ECM.
looks like I am going to keep the engine harness so I can use parts off of it for my TBI to TPI harness mod.
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
165 ecm and 87 harness is MAF, not SD.
Car: 87 irocz 305 5.0 5 speed G92 option
Engine: 305 tpi
Axle/Gears: 9 bolt 3.45 factory gears
If only this was a 5 speed harness... I need one for my 87 305 TPI 5 speed.
Hey guys, I broke the entire lot up and reposted the whole ad over here. this time with a ton of pics.
https://www.thirdgen.org/forums/engi...ml#post5798060
