[NY] garage clean out
Car: 2013 ZL1 convertible
Engine: 6.2 supercharged
Transmission: 6l90e
garage clean out
Just cleaned up the garage, have some parts left over. Garbage day is thursday, if not sold going to the garbage. thanks for looking, everything is obo i know its against the rules but i dont know what to charge for some of this stuff.
Corvette crossfire injection intake all new gaskets ported with tuning tools
305 crossfire top plate with injectors
305 and 350 Ecs
Crossfire fuel lines
82-84 corvette motor mounts
Tuned 350 prom from crossfireinjection.net
Swaybar bushings
Torque bar bushing
7.6 pinion seal
2.73 gears
305 and 350 Ecs
Swaybar bushings
Torque bar bushing
7.6 pinion seal
2.73 gears
Transmission: 6l90e
Re: garage clean out
From crossfireinjection.net
Our chip is similar to others in the marketplace only much cheaper. There is increased fueling, spark and improved TCC settings. This chip will cure a condition known by a GM TSB as "chuggle", a low speed surge. We do not make any claims of "You will get X amount more horsepower" for the simple reason each motor may have different setups and conditions of repair vary. This is for a stock motor, but can be used with smaller cams, ported manifolds and 2" throttle bodies. Performance you can feel. NOTE: THIS CHIP IS FOR 1984 CORVETTE 700R4 AUTOMATIC TRANSMISSION ONLY
Transmission: 6l90e
Ttt
Also have new t-top seals $100+
And new hood seals $10+
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
Randomtask2
Sep 10, 2015 08:37 AM
84 TA NV
Sep 6, 2015 08:02 PM
