[IA] a couple electric fans F/S!
Old 12-02-2014, 11:55 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
I have (2) electric fan assemblies for sale.
1.) A used Dodge/Chrysler dual fan, dual speed assembly w/complete relay control harness ready to go-no bearing noise, fans have been tested, cleaned and harness kit pre-wired and included. Requires (2) temp switches, I include in the harness a sealed 40A fuse and 2 HD Tyco relays rated at 40A and 50A. Asking $159 plus shipping.
2.) A used Motorcraft RF24 dual speed single fan (similar in appearance to a Mark VIII) and is also pre-wired with a relay control harness using Tyco 50A and 70A relays. This fan is a hurricane force fan assembly on high speed! Depth is 5.75" but can be trimmed to 5.25" so check radiator-water pump clearance on this one. Fan motor has been tested for bearing noise and assembly is nice and clean as well. This fan uses one of my exclusive MIDI screw down fuse holders and I include a 60A fuse with it. Asking $169 on this one. PM for more info or pics. I'll post pics soon-I need to format the images to get under the size requirement.
Old 12-03-2014, 10:31 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: a couple electric fans F/S!
Here's the RF24 dual speed fan assembly. I use high capacity dual 70A relays for durability and a 50A rated switching relay. These relays are NOT your parts store relays either-they feature internal resistors and flyback diodes to eliminate high inrush current and damaging voltage spikes. Very stout setup.
Attached Thumbnails a couple electric fans F/S!-img_20141203_213845_816-1.jpg
91L98Z28
Southern California Area
09-19-2015 09:35 AM
64goatman
09-09-2015 01:09 PM
85Special
09-03-2015 04:21 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
Quick Reply: [IA] a couple electric fans F/S!
