[Sold] GM AL 1.6 rockers, screw in studs
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
These have less than 1000 miles on them, so are like new. I am only selling due to upgrades. Asking $210 shipped in lower 48 OBO. Will separate if desired.
http://www.jegs.com/i/Chevrolet-Perf...10729/10002/-1
Re: GM AL 1.6 rockers/studs
Thread updated.
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
The pushrods are stock length for your motor. The rockers are self aligning, require screw in studs, and may necessitate removing material from the pushrod slots in your cylinder heads.
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
How much for the lot shipped to 97016
$290 shipped in the lower 48 for rockers, pushrods, and studs.
Re: GM AL 1.6 rockers, studs, CC 7608 pushrods
Price lowered to $265 shipped in the lower 48.
Car: 85 Trans Am
Engine: carbed 350 four bolt
Transmission: 700R4 with shift kit
Axle/Gears: 373's
Why are they different then the roller rockers in the link?? The one u have a silver in color those are blue? And have a slightly different body shape???
The color makes no difference. Mine are from the old Hotcam kit; the examples on Jegs are what you would get using the P# from the kit. Again, no marked difference in function.
Car: 85 Trans Am
Axle/Gears: 373's
O I see thanks for clearing that up for me... il keep thease in mind im waving some options on what direction im going with for the rockers.... thanks for the reply man
Car: 85 Trans Am
Axle/Gears: 373's
I wouldnt need the pushrods ether... do you know how much spring pressure the r.rockers are rated for? It didn't say in the link
Pushrods sold. As far as the spring pressures these rockers will work fine unless you are going crazy with the cam, which at that point a NSA rocker setup (guideplates) is recommended anyhow.
$210 shipped for rockers and studs.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: GM AL 1.6 rockers, screw in studs
Thanks for the pushrods, I'm sure 330-350psi on the rockers
RedLeader289
May 28, 2019 01:47 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
