Poly V8 mounts, TPI dist cover, 145 cluster, TPI ECU, ss trans lines, 3k stall & more
Old Feb 3, 2015 | 06:00 PM
Casey Meyers's Avatar
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
Energy Suspension polyurethane engine mounts already installed in clam shells, used for about 5k miles, in great condition. $30
TPI distributor cover, has small blemish towards rear (can see in pic, was from drill bit) no screws. $30
145 mph camaro cluster, from my 86. Trip odometer does not work, speedometer needle would bounce around at about 80 and about 140. VSS works, all other gauges work. Circuit board looks good, is missing a clip for the tach and another is damaged, is shown in picture. Two holes are drilled into it behind tach, clear cover has minor cracks, gauges screws are missing as well as bulbs. $50
Stainless steel trans cooler lines with auxiliary cooler added. $65
10" 3k stall converter. Cannot remember brand but has about 10k miles on it. $100
Stock V8 k-member and control arms, good condition. make offer
Stock Z28 calipers,good condition. make offer
TPI ECU Service #1227165 chip is AUM 0122. $50
Can ship smaller items
Attached Thumbnails Poly V8 mounts, TPI dist cover, 145 cluster, TPI ECU, ss trans lines, 3k stall & more-20150203_175448.jpg   Poly V8 mounts, TPI dist cover, 145 cluster, TPI ECU, ss trans lines, 3k stall & more-20150203_175501.jpg   Poly V8 mounts, TPI dist cover, 145 cluster, TPI ECU, ss trans lines, 3k stall & more-20150203_182551.jpg   Poly V8 mounts, TPI dist cover, 145 cluster, TPI ECU, ss trans lines, 3k stall & more-20140519_175435_1.jpg   Poly V8 mounts, TPI dist cover, 145 cluster, TPI ECU, ss trans lines, 3k stall & more-20150126_161904.jpg
Poly V8 mounts, TPI dist cover, 145 cluster, TPI ECU, ss trans lines, 3k stall & more-20150120_164647.jpg
Old Feb 3, 2015 | 09:04 PM
wildmon69's Avatar
Car: 86 T/A/1990 Firebird
Engine: 5.3 L33 pt7675 / Ls1
Transmission: 4L80E/T56
Axle/Gears: 3.73/4.10
Re: Poly V8 mounts, TPI dist cover, 145 cluster, TPI ECU, ss trans lines, 3k stall &
I PM'd you about the motor mounts.
Old Feb 3, 2015 | 10:12 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Interested in the 3k converter. Do you have any more info on it?
Old Feb 4, 2015 | 06:56 AM
Car: 86 Z28
Engine: 385 HSR
pm responded to.
as for the convertor, i was told by the previous owner it was a tci but the numbers on it come up with nothing on google. i ran it in my car but the stall speed was too high for my tpi setup and switched it out for a 2400, but have now gone to a manual
Old Feb 4, 2015 | 02:04 PM
89CamaroAndrew's Avatar
Car: 89 Camaro Rs
Axle/Gears: 3.45 9 bolt
what year camaro did the ecu come off of?
Old Feb 4, 2015 | 03:03 PM
Car: 86 Z28
Engine: 385 HSR
1986
Old Feb 4, 2015 | 09:07 PM
seiplentz's Avatar
Car: 85 Z28
One more question about the converter. Do you know its a lockup or non-lockup?
PM sent
Old Feb 5, 2015 | 05:57 AM
Car: 86 Z28
Engine: 385 HSR
Engine mounts are sold
Old Feb 5, 2015 | 10:37 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
How much on the gauge cluster shipped to 08527 and do you accept paypal?
Old Feb 6, 2015 | 03:37 AM
Car: 86 Z28
Engine: 385 HSR
Converter sold. Pm sent
Old Feb 6, 2015 | 06:28 PM
Car: 86 Z28
Engine: 385 HSR
Gauge cluster sold
Nervous2
Oct 8, 2015 10:53 PM
eightTfourTA
Feb 16, 2008 05:30 PM
mw66nova
Sep 10, 2007 11:00 AM
wrenchman1213
Jun 5, 2007 03:28 PM
