Performance Parts
Old Mar 17, 2015 | 03:37 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Performance Parts
Any interest in these performance SBC parts? I've got a split combination (1.52/1.6) set of Comp Cams Pro Magnum rocker arms. They are a full roller rocker. Non-self aligning. Guide plates included. $175 + shipping.
A set of CP forged pistons. Originally manufactured for SB2 but they will work for a budget 400 SBC build with 6" rods. They are dished. They are 4.125" + .010 over size. They have dyno time only. One piston had to be replaced. It cracked under a NOS hit. Skirts are very nice. I did send them back to CP and they are verified to be in very good condition. $250 + shipping.
Attached Thumbnails Performance Parts-ccrollerrockers.jpg   Performance Parts-comprollerrockers.jpg   Performance Parts-cppistons1.jpg   Performance Parts-cppistons2.jpg   Performance Parts-sb2_1.jpg
Old Mar 17, 2015 | 05:15 PM
91 rally sport's Avatar
Car: 85 iroc z, 03 ram 1500
Engine: 305 tpi, 287
Transmission: WC T5, NV3500
Axle/Gears: 3.42, 3.55s
Re: Performance Parts
Are the rockers 3/8?
Old Mar 17, 2015 | 09:28 PM
wesilva's Avatar
Transmission: 200R4
Yes.
Old Mar 18, 2015 | 07:34 AM
Do you know about how many miles are on them?
Old Mar 18, 2015 | 10:52 AM
wesilva's Avatar
Transmission: 200R4
Less than 15,000. They are in very good condition. No issues. They are rebuildable but are no where close to that. You'll be happy with them. They must be used with rocker arm studs because that's how the guide plates mount.
Old Mar 18, 2015 | 12:32 PM
Ok so they should bolt right on to my 85 305?
Old Mar 18, 2015 | 03:13 PM
wesilva's Avatar
Transmission: 200R4
Do your heads have screw-in studs? You need screw-in studs so you can mount the pushrod guide plates. See photo. If your heads have pressed in studs, they will not work.
Old Mar 18, 2015 | 03:49 PM
Crap I still have the stock pressed in ones. Thanks
LT1Formula
20
Nov 14, 2015 12:02 AM
86IROC112
Aug 17, 2015 02:00 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
