FS: 305 SBC Piston & Rod Set
Old May 2, 2015 | 01:55 PM
StenInDotte's Avatar
Want a title? Post!
FS: SBC 305, never used set of Silv-O-Lite Pistons, PN H1482+0.030. Keith Black Series, Hypereutectic Cast aluminum, Flat-top with 4 valve reliefs. Compression Distance (in):1.540 in. Wrist Pin Style:Press-fit Pin Diameter (in):0.927in offset Piston Ring Thickness:5/64 in. x 5/64 in. x 3/16 in. With stock rods / pins already installed. Big end of rods has been honed, I do not know to what size. Weight of rod-piston assembly is about 1,305 grams. These are a nice set of replacement pistons-rods. If you want 300+ HP and nitrous, I wouldn't use these. If you want to freshen up your 305 with a +0.030 overbore and reduce the weight from stock, this is your ticket. The Silv-O-Lite catalog lists these as 9.5-1 comp. pistons. $150 / offer + shipping for the full set of pistons and rods. Located in SE Michigan, keep in mind the shipping weight will be about 25 pounds if not local pickup.
84z96L31vortec
Aug 20, 2017 12:16 AM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
