[PA] Parting out an 86 Z28 305 TPI
Parting out a 1986 Camaro Z28 . Motor is a 305 TPI with a mild cam. Motor runs excellent. Motor has rougly 50k miles on it. No smoke or leaks. Other mods are HEI distributor with Accel Super coil and Accel wires. MSD 6AL ignition box, Edelbrock headers and y-pipe with aftermarket catalytic converte, 2.5 " exhaust with Flowmaster muffler, aluminum water pump, newer injectors, aluminum pulleys and chrome valve covers. Trans is a 700 R4 ( was rebuilt but now stuck in first gear ). Finally it has a 10 bolt posi drum brake with 3.73 gears. Also has Air Lift bags in rear coil springs to help with traction at the track. Car went consistent 14.1-14.2 at Atco the couple times it was taken. Have video of car running I can text to you. Motor is currently in the car so you can hear it run. Prices are the following:
3) 305 TPI motor sold as long block $375
4) 700 r4 trans ( good for a core. may be fixable w/o a full rebuild) $85
8) overhead interior console $50
15) set of (4) 15" gray Z28 5 spoke wheels with tires. Wheels are in good shape. No curb rash. Tires need to be replaced. $150
this is not a total part out. Not selling any other body parts. May sell some interior parts)
Car will be sold as roller once these parts are sold. Would make good race car. Floors and 1/4s are rock solid. Needs some body work.
Located in Hatboro, Pa
Re: Parting out an 86 Z28 305 TPI
1) 305 TPI motor complete from intake to oil pan with aluminum pulleys, alternator and p/s pump $550
2) 305 TPI motor less acessories ( no alternator, ps pump or pulleys) $475
3) 305 TPI motor sold as long block $400
4) 700 r4 trans ( good for a core. may be fixable w/o a full rebuild) $125
5) 10 bolt drum brake posi rear w/ 3.73 gears $400
5) rear coil springs with air bags $75
6) Grid tail lights $80pr.
7) 3 pc. rear spoiler $80
9) aluminum pulleys $ 75
10) MSD 6AL ignition box ( old style not digital) $125
11) hood louvers $50 ( 1 louver has pc chipped off)
12) complete TPI /engine harness $60
13) Edelbrock headers / Y pipe and catalytic converter $180
14) 2.5 " exhaust with Flowmaster muffler $150
15) set of (4) 15" gray Z28 5 spoke wheels with tires. Wheels are in good shape. No curb rash. Tires need to be replaced. $165
16) ECM with Hypertech chip $80
85@IRocZ
Dec 15, 2015 05:22 PM
