1986 Camaro Z28 T5 Project!! COLOR CHANGE!!
Old Nov 19, 2015 | 08:31 PM
Maro86Z28's Avatar
Car: 1986 Camaro Z28
Engine: Chevy small block 305 c.i. 5.0
Transmission: World Class Barg WARNER T5 -5 Speed
Im the OWNER of the 86 Z28. It has a 305 c.i. WC -T5 5speed Trans. factory gears i think their 3.23 I'm closing down my shop and no longer have a place for it need to sell!!!! The engine was rebuilt 5,000 miles ago with .30 over cylinders surfaced stock heads "polished" ports with valve job New oversized rings and Pistons. Mild cam {Comp cams K12-238-2 KIT} NEW Oil pump fuel pump. 750 CFM Edlebrock carb. weiand 7546 high rise manifold. Accel H.E.I Distributor, super coil, copper wires, bosch platinum plugs Headman short headers to Y-pipe to one 3in. pipe NO CAT. Email for pictures if serious: Derecklb89@gmail.com.
This is the sanding stage car was originally painted metallic GM GRAY" from the factory and repainted green.
More pics of body work and shaved door handles!!
The car had been in a small shop accedent bending the fender and bumper. You can see here in this photo.
I took the bumper off and replaced the headlight rail, bumper, and fender.
Heres the new headlight rail!!
Here's the project all together
Old Nov 19, 2015 | 08:34 PM
Maro86Z28's Avatar
Old Dec 18, 2015 | 03:26 PM
Maro86Z28's Avatar
Re: 1986 Camaro Z28 T5 Project!! COLOR CHANGE!!
265/45/18
Primer stage Heavy coats of Lacquer Primer to go under a Polyurethane coat!!
Fitting new wheels Boss 338 18/10 rear 18/8.5 front!!
Primer stage removed all Ground effects for TRUE color CHANGE!!
painted in door jams
after primer
new paint!!!
Old Dec 29, 2015 | 03:02 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Should be looking sweet after a bit of dry in and a good cut-n-buff.
Old Feb 5, 2016 | 08:38 PM
Dbruce8112's Avatar
Car: 08 TBSS
Engine: LS2
those wheels are Money! the cars gonna look killer after your done!
Old Jun 1, 2016 | 12:16 AM
Maro86Z28's Avatar
thnx she's done and im proud!!!!!!!!!
Old Jun 1, 2016 | 12:19 AM
Maro86Z28's Avatar
Old Jul 2, 2017 | 09:57 PM
Billgluckman's Avatar
Got any better pics?
Tyler1986
Mar 15, 2013 08:27 PM
White_Wolf
Aug 30, 2010 10:52 PM
Shadow010
Oct 12, 2001 10:05 AM
