[NC] Camaro/Trans Am/Firebird Parts (Waxhaw, NC, 28173)
Car: 1989 Pontiac Firebird Trans Am
Engine: 5.0 305 V8 FI
Transmission: 700R4 Automatic
-1x set of Custom valve covers (blue inferno skulls)
-1x TPIS PROM adapter, never used
-1x 85mph Trans Am cluster
-1x '69-'95 GM V8 harmonic balancer (6 3/4" x 2 3/8")
-1x set of manifold restrictor insert
-1x drivers Trans Am door
-1x passenger Camaro door
-1x starter
-1x GM coil
-1x MSD GM coil
-front pulleys/brackets
-1x rear view mirror
-1x set of "duck tail" spoiler ends
-1x set of front set belts; grey
-1x set of front markers
-1x stock radio
-1x set of side mirror trim
-1x head light bezels
-1x center console lid; without cover
-1x idler pulley
-1x set of Camaro turn signals
-1x set of motor mounts; engine & car side
-1x set of solid motor mounts; engine side
-2x cruise control
-1x gauge bezel; without plastic lens
-1x gauge bezel; with plastic lens
-1x Corvette 9th (cold start) injector
-1x roller cam spider
-1x transmission mount
-1x timimg gears
-1x V6 throttle body
-2x V6 coil packs
-2x EGR
-1x heater bypass valve
1x dipstick
-1x electric hatch solenoid
-2x thermostat housing
-1x oil pick up
-2x A/C dryer
-10x lug nuts
-3x locking lug nuts
-16x Camaro injectors
-1x (91194-1) transmission gasket; new; 700r4
-1x set of (CC400) cam bearings
-15x roller rockers
-1x roller cam retainer
-1x adjustable fuel pressure regulator cap
-1x fuel filler lid
-14x comp cam 7/16 hi-tech polylocks
-1x 3rd gen Camaro intake
-1x set of Firebird taillights
-1x Camaro Passenger Taillight
-1x passenger tail pipe
-1x blower fan
-2x Trans Am center caps
-3x 3rd Gen Camaro/Firebird radiator
-1x 4th Gen Camaro/Firebird radiator
-1x big cap distributor, Carb
-2x small cap distributor, TPI
-1x set of 10.2 mm wires
-1x Carburetor intake
-1x Aftermarket break distributor block (proportioning valve), brand new, never used
-2x Break distributor block (proportioning valve)
-1x '89 smog system
-random '89 and '85 Trans Am interior
-early 3rd gen or late 2nd gen Seats; front and back - red
-1x 1985 Trans Am passenger door panel
-1x 3rd Gen Firebird/Trans Am dash
-1x ECU re-manufactured
-2x TPI runners
-2x TPI plenums
-2x TPI intake manifold
-2x TPI fuel rails
-2x throttle bodies
-1x Adjustable fuel pressure regulator
-1x set of LT1 injectors
-1x MAF from '89 Trans Am
-1x starter
-1x GM coil
-1x MSD GM coil
-1x stock radio
-1x idler pulley
-2x cruise control
-1x timimg gears
-2x V6 coil packs
-2x EGR
1x dipstick
-1x oil pick up
-2x A/C dryer
-10x lug nuts
-15x roller rockers
-1x fuel filler lid
-1x blower fan
-1x '89 smog system
-2x TPI runners
-2x TPI plenums
-2x TPI fuel rails
-2x throttle bodies
Re: Camaro/Trans Am/Firebird Parts (Waxhaw, NC, 28173)
Taking offers on it all. What all would you need?
Car: 1969 camaro
Engine: 90 TPI
Transmission: 400turbo
Do you have the front serpentine accessories and a throttle cable. Also a 700r4 TV cable for TPI
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
Is any of the TPI stuff aftermarket? Specifically the intake manifolds and the lifters.
Car: 85 iroc z, 03 ram 1500
Engine: 305 tpi, 287
Transmission: WC T5, NV3500
Axle/Gears: 3.42, 3.55s
Pictures and price for the fpr
camaroracer21
Dec 5, 2015 09:02 PM
KENS80V
Feb 6, 2010 07:20 AM
86TA4SALE
Jan 13, 2010 07:15 PM
Nervous2
Sep 11, 2008 09:20 PM
