[AL] 083 L98 heads ported
Old 01-08-2016, 11:00 AM
smithtc's Avatar
iron L98 heads 083 for sale
ported, surface milled & opened up for 2.02/1.60 with performance valve job
machined for screw in studs. guideplates or self aligning rockers required.
they are taking up space, sitting for a while. make a reasonable offer.
$300 shipped or best offer
Old 01-08-2016, 03:47 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Re: 083 L98 heads ported
Who did the work and mileage? Any pics?
Old 01-12-2016, 02:59 PM
smithtc's Avatar
I did the porting. I'm an Engineer and I used that experience to approach porting in a technical manner. There is plenty of room for additional porting if one was interested.
Machine shop did a little clean up for me, plus the machining for screw in studs and valve spring seats, valve job, etc A performance place that doesn't exist anymore after the recession hit. These were done about 10 years ago.
Miles? Probably about 5000 miles. Not much, but I don't recall exact.
I'll see about getting some pictures.
Old 01-12-2016, 03:19 PM
smithtc's Avatar
Flow numbers when they were in stock condition then ported with Manley Valves 2.02/1.6
Intake
Lift_______CFM
0.097...52
0.194...101
0.291...145
0.388...167
0.485...179
0.582...185
Lift_______CFM
0.075....35
0.150....62
0.225....87
0.300....105
0.375....106
0.450....106
2.02-1.60 w/ Manley valves
Lift......Intake....Exhaust
.100....56.43.....48.22
.200....113.36...105.54
.300....163.94...146.51
.400....191.16...166.22
.500....197.16...170.49
.600....202.70...171.34
Old 01-13-2016, 12:41 AM
89-S-dime's Avatar
Engine: 350 TBI build
Axle/Gears: 3.73 G80
Intake
Lift_______CFM
0.097...52
0.194...101
0.291...145
0.388...167
0.485...179
0.582...185
Lift_______CFM
0.075....35
0.150....62
0.225....87
0.300....105
0.375....106
0.450....106
did you notice a differences in performance after porting was done?
Old 01-13-2016, 09:41 AM
smithtc's Avatar
Short answer...yes.
89 GTA 350 with 700r4 and 3.27 gears. Street tires, no drag radial.
Stock block high mileage.
1-5/8 headers and exhaust
Lingenfelter Runners, ported plenum, and intake.
Stock L98 camshaft, injectors, a hypertech chip. I believe .415/.430 stock don't recall duration on the cam.
I had these heads I'm selling from another car and was porting and getting the work done at the machine shop. I got tired of waiting for the machine shop to turn them around so I took off the original 083 heads on the car...did a quick bowl blend and reinstalled same day. same rockers, valve springs, etc. Car ran 8.48sec in the 8th at around 81-83mph (don't recall exact mph).
Finally got the heads back from machine shop and installed. Car went from consistent 8,8s before any porting at all to 8.6s, but never eclipsed the 8.48. Thats the best my memory serves up.
Had plans for additional changes but life happens... Car needed an upgrade in camshaft or I never really got a chance to tune or make other small changes to take advantage. Actually, I was planning to build a new short block and use the Hot Cam or 219 LPE cam to go with these heads. Just never happened.
I still have the 083 heads with just the bowl blend as well....
Old 01-14-2016, 09:04 AM
Irocan88's Avatar
Car: 1988 Iroc Z
Engine: 5.7
Axle/Gears: 9 bolt 2.77
PM sent
Old 01-18-2016, 10:57 AM
Irocan88's Avatar
Car: 1988 Iroc Z
Engine: 5.7
Originally Posted by Irocan88
PM sent
Have you already sold these heads? I haven't heard anything back from you.
Old 01-22-2016, 11:17 AM
smithtc's Avatar
Still have the heads...
I pulled them out of storage to take some pictures and they have some surface rust in some areas I wasn't expecting. I'll have to clean that up before I can sell them...
Old 01-22-2016, 11:48 AM
Irocan88's Avatar
Car: 1988 Iroc Z
Engine: 5.7
Don't mind surface rust, they would be gone through thoroughly and be sitting for a bit until I get back to the states anyhow. Can you send me some pictures to my email? fuentesadan83@gmail.com thanks!
Old 01-30-2016, 10:14 PM
Want a title? Post!
Jdinmd's Avatar
I'd be interested in them "as is" too. How about some pictures please? Thanks
Old 02-06-2016, 08:13 AM
80s Poncho's Avatar
Car: 1989 Pontiac Formula /1985 Trans Am
Engine: TPI 350 / TPI 305
Transmission: 5 Speed / 4 Speed Auto
Axle/Gears: 323
Do you still have these heads? If so do you have paypal?
Old 02-06-2016, 09:41 AM
Irocan88's Avatar
Car: 1988 Iroc Z
Engine: 5.7
Good luck man , I've tried multiple ways of contacting him to no avail. I was and have been ready to buy them from him but seems he lost interest in selling them now.
Old 02-06-2016, 10:19 AM
Want a title? Post!
Jdinmd's Avatar
Sounds like they might be in worse condition than he thought.
Old 02-27-2018, 12:03 PM
smithtc's Avatar
Still for sale. Life got in the way (moving, work, divorce)
So here are some pictures.
Attached Thumbnails 083 L98 heads ported-20160306_173453.jpg   083 L98 heads ported-20160306_173711.jpg   083 L98 heads ported-20160306_173727.jpg
Old 03-09-2018, 08:50 AM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Pm sent
yaj15
02-25-2016 10:30 PM
Jdinmd
02-16-2016 06:22 PM
fire7rescue
01-26-2016 08:44 AM
soarestransam
Brakes
01-12-2016 01:21 PM
marco33
01-08-2016 07:49 PM
Quick Reply: [AL] 083 L98 heads ported
