Dynamic EFI / EBL FLash - $365
What's up guys... ...I'm selling a brand new, un-used Dynamic EFI / EBL Flash set up with everything included, including the USB/serial adapter. It does NOT have the "port" mod done, but you could have it done for another $25 at Dynamic EFI. Again, brand new, never used.
It's a great EFI set-up, but I ended up going another route with my car. Everything together, as you can see from the paperwork was $465. I'll take $365 plus shipping, for an easy $100 off.
Thanks guys,
Chris
Thanks guys,
Chris
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
Re: Dynamic EFI / EBL FLash - $365
The port mod is needed for TPI, correct?
Also, are there instructions on how to set it up and tune everything? What else is needed? I want to go dynamic efi but really have no clue on how to do it.
Is there any way to keep the MAF setup? I've already bought several parts like a new MAF sensor and K&N CAI setup, plus I would have to buy the later style TPI intake.
Well the computer uses readings from a MAP sensor which measure pressure, as opposed to the MAF, which measure air flow volume. So in that regard, I don't THINK so, but I could be wrong. There are plenty of reasons to make any decision you need to make, but I wouldn't NOT go EBL because of that. Big improvement over the MAF set up.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
so for another $25 with shipping Dynamic EFI. will set this up with the port" mod . to plug into the Lap Top. right?
and ths is the set up for the later/last tpi 88/92 MAP cars..right
The port mod, as I understand it is for "multiport" like our TPI's as opposed to a throttle body style intake. ...as it is, you can definitely plug it into a laptop.
...and since it's an entire ECM, you can really use on whatever you like, assuming you have the proper harness. For my '89, there was minimal harness work required, and detailed instructions as to exactly which wires to move.
mizz0313
Feb 29, 2016 07:17 AM
B4C5.7
Feb 22, 2016 08:34 AM
84strokerbird
Feb 18, 2016 02:21 PM
GFusick
Feb 17, 2016 11:37 PM
