Jeep cherokee and Astro van steering shafts
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Jeep cherokee and Astro van steering shafts
Bump. I have two more combo sets left. $75 shipped to the lower 48
bump
I have 5 shafts and bearings ready to go. Bump
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
They are used but tested, cleaned and regreased. I do have some available
Car: 92 RS Hardtop
Engine: soon to be LS
Transmission: soon to be T56
Car: 92 RS Hardtop
Got the package in Saturday. Looks good! Added to the parts stash for when assembly starts next month.
Thank you!
Thank you!
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Car: 92 IROC-Z
Engine: 5.0
Transmission: 5 Speed Manual
Got mine a week ago. Haven't had a chance to install it but everything definitely looks good2go
Car: 86 Sport Coupe
Engine: 5.3 LM7
Car: 86 Sport Coupe
Engine: 5.3 LM7
Car: 92 RS Hardtop
Ok I got the last batch out for those who have already ordered. I have 5 more shafts and 2 bearings left as of today.
Bump
Car: 1983 Chevrolet Camaro Z28
Engine: LS3
Transmission: Tick TR6060 w/ Mantic 9000 clutch
Axle/Gears: Strange S60 w/ 3.73 True Trac
I PM'd you Robert Frank, really looking forward to getting one of these!
I responded on my Endgame Performance page
Ok anyone who put out orders last week, everything is going in the mail today. I do have two more shafts ready to go. I also have one Astro bearing left. $75 shipped to the lower 48. PayPal is rfrank1980@yahoo.com
Car: 1989 Firebird KITT Replica
Engine: 305 TBI L03
Finally had a chance to install this mod today (shaft and bearing). Everyone makes it look easy in the videos, and yes, in theory, it should be easy, but MAN, what a PAIN THE THE ****!!
Unbolting near the power steering pump was easy, as was near the firewall. Sliding off near the PS pump, relatively easy. Sliding it off at the other end, ARGH!!! took me maybe an hour to wiggle it off, beat it with a hammer at weird angles etc. Finally got the idea to turn the wheel a half turn to expose the thru-bolt hole and use a screwdriver as leverage. Voila!
Then the dreaded bearing. The old bushing is rubber, so it doesnt just slide off. Again, more wiggling and turning to get it off.
Finally got that off, and low and behold, my Astro bearing does NOT fit at all. It does not fit on my steering column. I cant even get it started. Seems like the bearing is too small, although it looks the same size as my old bushing. Very weird. If anything, it would have to be pressed on, but at this funny angle and clearance, good luck with that.
Trying now to wrestle the old bushing back into place....ugh. Hopefully the steering shaft itself will be easy to install.
Did you try greasing up the column beforehand? Had to do it when I first started using them then tapping it up with a hammer
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Engine: 305 TBI L03
Nope, bought one from the seller here, the OP of this thread. Looks like a used astro bearing to me.
Just cleaned up the shaft, lubed it, but I cannot even get the bearing on at all, not even straight enough to hammer it on. Oh well
Car: 1987 Camaro LT
Have you seen this vid on you tube? It was quite helpful when I was installing mine which I got from the wrecking yard. Where in L.A. are you?
https://www.thirdgen.org/forums/susp...g-bearing.html
Sorry for the issue you're having. Send me a PM and I'll take care of it
Ok everyone who ordered a shaft last week they will all be shipped out first thing tomorrow morning. I got into an accident at work and it put me a little behind but all is good now. I do have three more Astro shafts available.
I have six shafts available. Bump
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
pm sent
ok all orders that came in Last week were shipped out yesterday. I have 6 more shafts ready to go
Car: 1988 Firebird Formula
Axle/Gears: 3.23 4th Gen w/ powertrax locker
you still have both shafts and what prices are they running with shipping?
