[Sold] FIRST intake, ported with injectors
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Hi,
Selling my FIRST tpi intake.
Comes with 42 lbs bosch green giant injectors and an extra set of intake runners. One pair of runners has a window bored through during porting, other 3 pair are new except for some black paint sprayed on them.
Runners are bored to 1.75-1.8" and siamesed around 2 inch , intake ported and siamesed to match. Combo works very well on the street, and is a very fun intake. I have decided to change my set up going forward, so its time to sell the FIRST.
Asking $850us obo.
Included:
intake
plenum
runners
extra set of runners
Throttle body
TPS sensor and bracket
throttle cable bracket (been cut and welded, but works)
IAC motor
air intake sensor
injectors 42 lbs bosch
injector rails
runner bolts
old gaskets
Not included:
intake mounting bolts
new main gaskets
thermostat housing
fuel pressure regulator
Asking $850us obo.
Included:
intake
plenum
runners
Throttle body
IAC motor
air intake sensor
injector rails
runner bolts
old gaskets
Not included:
new main gaskets
thermostat housing
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: FIRST intake, ported with injectors
Does it include throttle body, gaskets, hardware, TPS bracket, throttle bracket, and fuel rails? Are you running it with the stock ecm or another?
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Fyi, the car was running with the stock mass air and 165 ecm for a couple years, and then I switched out to the EBL sd set up.
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
What engine combo are you running this with and what intake are you changing to?
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
You were running 42# injectors with a 165 computer and Maff?
Engine: 4++,350 & 305 CIs
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Car: 87 Iroc
Did you have a chip burned to run the 42# injectors with the stock 165 computer and Maf?
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Car: 87 Iroc
Thanks ,I am running a 400 small block with 503 comp cam full retro roller assembly with 220 cc heads. I am running a Edlebrock base ported plenum with stock runners.I was looking for bigger runners.But the First could be a better way to go.
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
it would definitely be a better choice in every way.
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Car: 87 Iroc
Were you able to find the 165 chip you used to run the First?Thanks,Steve
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Sale is pending for complete intake system and Cam, I will let you guys know, and I dont have an issue parting it out if needed.
