[NV] 1991 Firebird Formula 350 TPI PARTS CAR for sale
Old May 2, 2017 | 08:36 PM
Firechickenv6's Avatar
Car: 1991 Firebird
Engine: 5.7L V8 TPI
Axle/Gears: 10-bolt posi w/drums
UPDATE 5/19:vehicle sold to tealman92
Looking to sell/part out my 1991 Firebird Formula. The car was totalled over 10 years ago, was bought as salvage from the insurance company. I kept it to use as a donor car for another third gen I had at the time, but have since sold. Now she's just taking up garage space...
I have the title in-hand, and would prefer to sell the car as a donor car to a local buyer within towing range. She's NOT a driver anymore, as some parts were swapped, sold or damaged. However, I'm willing to part out the rest if I can't find any takers.
Now some info:
1991 Firebird Formula Coupe (no T-tops)
-Green w/tan interior
-Pioneer Speakers front/rear (installed by previous owner, before me)
-WS6 suspension (factory)
-Suncoast Creations WS6-style Ram Air hood (Ram Air kit included, but not installed)
-16" Silver (salad-shooter/Factory) wheels (tires flat, LR bent in accident)
-Factory Trans Am fog lights (added)
-Dual cat exhaust (factory)
-Tokico blue (non-adj) shocks/struts
-front disc/10-bolt rear drum brakes (factory aluminum drums were swapped to donor)
-GM Performance slotted/drilled front rotors with SS brake lines (front/rear)
-Spohn subframe connectors and LCA relocation brackets (weld-in)
-Founders Performance rear tubular LCA (Driver's rear is bent, due to accident)
-Lakewood adj. Panhard bar
-Jet Performance ECM chip, 160 Degree Tstat and low temp fan switch
-SLP Siamesed Intake runners
-TB Air Foil
-Fully ported Intake plenum by Corvetteplenum.com (if he's still around...)
-Adjustable Fuel Pressure Regulator (Accel, I believe?)
-B&M shift kit,Full-Throttle Kickdown valve in 700r4
-Torque Converter for a C4 corvette
-Aluminum coolant reservoir
-"Wonderbar" off a 3rd gen Z28
-Energy Suspension swaybar bushings and endlinks (front/rear)
-Accel 300+ Ignition system w/plug and play harness
-Accel Plug wires, Cap and Rotor
-Edelbrock Aluminum waterpump
The accident caused major damage to the LR quarter of the car. It bent the rear axle and the left LCA, damaged the rear decklid and spoiler (didn't break the rear glass tho), smashed a hole in the LR quarter panel and pushed it forward into the driver's door (and LR wheel) partially creasing the roof. SEE PICS...
As I said, the car has been sitting for 10+ years, so no guarentees on the condition/function of said parts. Interior is in relatively good condition.
MISSING items include:
-Driveshaft (sold)
-Battery (swapped)
-Air intake setup (swapped)
-Dashpad (swapped)
Also, a REMAN engine was installed by the previous owner back around the 35k mark and the car now had a bit less than 90k on the odometer when she was totalled and left to sit. So the engine itself has less than 60k on it (minus the 10+ years sitting).
The car is probably worth way more in parts than as a whole, but I would like my garage back and find myself to busy to work on her.
I'm asking $1000 or best offer for the car, or will part out if no local buyer is found. Feel free to message with any questions or for more pics, thanks!
Attached Thumbnails 1991 Firebird Formula 350 TPI PARTS CAR for sale-20150515_131439.jpg   1991 Firebird Formula 350 TPI PARTS CAR for sale-20150515_131455.jpg   1991 Firebird Formula 350 TPI PARTS CAR for sale-20170502_163048.jpg   1991 Firebird Formula 350 TPI PARTS CAR for sale-20170502_163036.jpg   1991 Firebird Formula 350 TPI PARTS CAR for sale-20170502_163041.jpg
1991 Firebird Formula 350 TPI PARTS CAR for sale-20170502_163137.jpg   1991 Firebird Formula 350 TPI PARTS CAR for sale-20170502_163206.jpg   1991 Firebird Formula 350 TPI PARTS CAR for sale-20150515_131844.jpg   1991 Firebird Formula 350 TPI PARTS CAR for sale-20150515_131942.jpg   1991 Firebird Formula 350 TPI PARTS CAR for sale-20170502_163449.jpg
Old May 2, 2017 | 08:57 PM
rhino1's Avatar
Car: 87 GTA
Transmission: TH350
Axle/Gears: 3:42
Re: 1991 Firebird Formula 350 TPI PARTS CAR for sale
PM sent
Old May 2, 2017 | 10:01 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Just curious what you'd want for the hood.
Old May 2, 2017 | 10:23 PM
Car: 1991 Firebird
Engine: 5.7L V8 TPI
I'd prefer to sell the car as a whole, so I'll hold off on quoting parts for the first few days. After that, I'll talk about piecing it out. Thanks
Old May 3, 2017 | 12:48 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Where in NV are you?
Old May 3, 2017 | 08:20 AM
Car: 1991 Firebird
Engine: 5.7L V8 TPI
I'm in the Las Vegas area. Henderson, actually.
Old May 3, 2017 | 07:17 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
that's my home town..Henderson...
was back in 2015 for SEMA..spent 8 days so I could look around...man has that place changed....not the same...
Old May 4, 2017 | 06:46 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I'd be interested in some of the tan interior parts if it gets parted.
Old May 20, 2017 | 10:19 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
I brought this one home yesterday. Ill be using some parts from this car for my restoration project. Ill part with what's left over.
Old May 21, 2017 | 01:26 AM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
What parts are you looking for from this car?
Old May 21, 2017 | 10:50 AM
rgauder's Avatar
Car: 1987 Trans Am
The wiring that connects to the power window switches? Maybe 10" of wire or so?
Old Jun 1, 2017 | 05:51 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
Nice, tan front seatbelt receivers
Old Jun 1, 2017 | 02:21 PM
Axle/Gears: 3.08
Those have been sold to another member already. There are some nice kick panels, carpeting, rear speaker covers, rear seat belt receivers, sail panels, and more that are in nice condition from this car however.
Old Jun 1, 2017 | 02:31 PM
Caddywampus's Avatar
Car: 1987 Camaro Iroc Z
Transmission: Automatic
Axle/Gears: 3:27
How much for:
-TB Air Foil
Old Jun 1, 2017 | 03:10 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
I purchased this car. None of the engine parts are for sale at this time. Everything else is. I have a parts for sale thread currently going for this car
Old Jul 21, 2017 | 04:33 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Not what I was looking for looking for a 4 wheel disc car
Old Jul 22, 2017 | 12:20 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Fyi. This car is equipped with the 4 wheel disc brake prop valve.
