Hey guys I'm thinking about selling my TBI system, I don't have the time or patience for the tuning.
250.00 - Brand new 54mm TBI unit from SPR Performance just paid 289.00
100.00 - 80Lb injectors just cleaned, flushed, and tested at WitchHunter Performance
25.00 - TBI to Spreadbore adapter plate from SPR Performance
350.00 - If sold all together
85.00 - LC-1 WB controller
40.00 - NEW TBI Distributor
65.00 - FPR for EFI
285.00 - EBL Flash
100.00 - Older 50mm TBI unit, ultimate mods, previously owned by V8AstroCaptain
Weiand 7531 Team G intake, powder coated black 220.00 https://www.ebay.com/itm/323383201029
Speed Demon 750, Annular venturi, with upgraded metering blocks 550.00 https://www.ebay.com/itm/323333364588
BUMP
BUMP
Want a title? Post!
Does the EBL have the port mod?
65.00 - FPR for EFI
265.00 - EBL Flash
Originally Posted by Rocket-Doc
Hey guys I'm thinking about selling my TBI system, I don't have the time or patience for the tuning.250.00 - Brand new 54mm TBI unit from SPR Performance just paid 289.00
65.00 - FPR for EFI
265.00 - EBL Flash
It was for a TBI setup, so no...
TTT
BUmp
TTT - If anyone wants pics just ask...
Hello, have pics of the distributor?
Ed
Ed
Ill have them up tomorrow.
Want a title? Post!
Do you have pics? Or do you still have this. I would be intersted in the whole setup if you still got it. I have an 83 crossfire trying to replace manifold up to single tbi setup.
I do, I need to get them (the pics) up. I have a 1/2 day off tomorrow. I'll do my best to get them posted.
Pics finally uploaded.
SPR Performance? Not sure what you are asking.
Bump
Do you have flow bench sheets for the injectors? What did they actually flow tested at what pressure?
What brand are the distributor and regulator?
Hope this helps...
Bump
Any adapter plate pics?
Also what psi range is the regulator and is it vacuum referenced?
This is the SPR Performance pic they have listed, it is the same: https://www.sprperformance.com/?ligh...aItem-inrmknbb
The regulator is made by Professional Products 15-60psi, and yes it is vacuum adjustable.
Ok I just noticed you have a WB. That's the Innovate LC-1 correct?
Also what is the model number on the FPR? All the blue ones I see are lower psi for carb setups.
Will you take $80 shipped on the WB?
The regulator is the predecessor to this one: Regulator Originally Posted by bluers91
Ok I just noticed you have a WB. That's the Innovate LC-1 correct? Also what is the model number on the FPR? All the blue ones I see are lower psi for carb setups.
Yes it is a LC-1
Any chance you still have the EBL flash?
Yes I do.
Would you go $250 shipped to 80112, and do you take PayPal?
So you do not want the injectors? Just the TBI?
No, I’m wanting the EBL flash ECU.
My apologies, was working on two things at once. 250.00 shipped message me your address and let me check on the shipping cost first.
No problem
PM sent
PM sent
Bump...
Payment sent for EBL
Got it Friday, thanks.
Bump for ya
Bump for ya
