[LA] NEW! 82-92 Tachometer circuit boards
#51
Re: NEW! 82-92 Tachometer circuit boards
Thanks Greg,
I got the board fast and just got it installed.It was set right on the money by my scanner no adjustment needed.
To the guys that need their tach fixed this is the way to go.
Thanks Again
Thanks Again
#53
Car: 85 Camaro RS
Engine: GEN I sbc 5.7, .040 over
Transmission: 700R4 Slushbox dreamkiller
Axle/Gears: 3.42 posi
Located in cenla, may be talking to you soon about repairing my tach. Ordered it from tgr and it's been pegged at 7k from the get go.
#54
Car: 1990 IROC Z Convertible
Engine: 305 tuned port
Axle/Gears: Stock
Hello,
I bought the tachometer circuit board fix from you back in Nov of 2017. The tachometer worked great until recently. When the car is started now, the tach needle barely moves. Is there a way to determine quickly if it is the circuit board or the tach that is the issue? I do not believe that I have the updated version with the LEDs installed. It is for a 1990 IROC-Z convertible. The item number I believe was 142457452416 and the transaction number was 5BM08872H31360602.
Any help would be appreciated.
V/R
Kerry
V/R
Kerry
#55
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Wootdog. Do you have an MSD or other aftermarket ignition system? Voltage spikes are not uncommon, but I install over-rated resistors to help avoid problems with voltage spikes.
What's your address? I will ship you a new one.
Thanks, Greg
Thanks, Greg
#57
Axle/Gears: Stock
Greg,
I have the completely stock setup. I will private message you my address.
V/R
Kerry
V/R
Kerry
#58
Engine: LB9 305
Transmission: AT
I have an 1989 Camaro IROC Z with the TPI 305 and AT. It's tach returns to 0 when off, but indicates MUCH higher RPM's than actual, when running. Sounds like I need your circuit board. I might swap the 305 for a 350, reusing the TPI and only changing the "PROM" in the ECU, fuel injectors and "Knock Sensor". Does any of this matter, to the way you construct the circuit board? Thanks.
#59
Car: 1987 Iroc Z
Thanks! Greg
#60
Car: 1987 Iroc Z
Hello,
V/R
Kerry
V/R
Kerry
Kerry, A new circuit board is in the mail. USPS tracking 9400109699939002935317
Thank You! Greg
#62
Car: 1987 Iroc Z
Not yet, but i would like to have one to see if I can duplicate it. Would you be able to send me a picture of yours so I can get an idea of its complexity?
Thanks, Greg
Thanks, Greg
#66
Car: 1987 Iroc Z
I sure do! Please paypal $45 as "friends and family" to cajuntachshop@yahoo.com.
I will have it in the mail as soon as payment is received.
Thanks! Greg
Thanks! Greg
#67
Just ordered one thru your website. Found out my tach is reading several hundred RPM high, did a quick forum search and what do ya know, here's the solution. It's nice to be able to support a small business like this, I'm actually kind of glad Dorman or some other company doesn't make this product. It's cool when someone figures out how to solve a problem and shares it with the rest of us.
#68
Car: 1987 Iroc Z
It's on the way!
Thanks! Greg
Thanks! Greg
Outkast Actual (10-23-2020)
#69
i have a 91 Z28 that the tach is alway reading the other side of the gauge. it dose move around when you turn the key on and off.
my question to you is do you still make the replacement boards and if so how much for one?
#70
Car: 1987 Iroc Z
hi. Yes I do. You can order on our website www.cajuntachshop.com or I can take your order over the phone. 318-402-1244
thanks! Greg
