[PA] MAP TPI Intake w/ swap stuff
Engine: LO5
Transmission: 4L60
Put this stuff together to swap into my Caprice, until the 700R4 let go and it got backed into in the same week...
Speed Density TPI Plenum/TB/runners/lower from a '91 Trans Am. Runners cleaned up really nice, only a few very minor dents, and just down low. Have all the torx bolts for the runners and lower intake.
Fuel rail/hard lines/regulator and a set of nearly-new Bosch III 24lb injectors. PN# 0-280-155-703 Originally purchased from SouthBay, they only have a few thousand on them.
Complete TPI harness from an 87(?) Was gonna disassemble it to repin my car.
Pair of original silver center-bolt valve covers.
Also includes all the other miscellaneous stuff I gathered: Brand new K&N filter for the TB and recharge kit. Original "Tuned Port Injection" plate for the TB, throttle cable, cruise cable, water outlet, EGR solenoid, MAP sensor, distributor cover, new Gates upper radiator hose
I don't have the coil, I was going to re-use my coil-in-cap dizzy, and I misplaced the little bracket that mounts the MAP. If it turns up ill throw it in.
Pictures in the next post. Asking $350 for everything and I prefer to sell the whole lot together. I'm just outside Philadelphia, pickup is very, very preferred, but I will ship at buyers expense. Drop me a line with any questions.
-Pat
-Pat
