[NY] 10 Bolt rear end 4.10 gear with Power Trax no slip
Old Apr 15, 2018 | 06:01 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
About to purchase a 12 bolt from Strange and figure I'll start trying to sell my rear end. 10 bolt drum rear end with welded axle tubes, has Richmond 4.10 gears with sold pinion spacer. Superior Axle 7.625 open carrier with Power Trax No slip locker, 28 spline Superior axles with 1/2 x 3 screw in studs. Also has Founders relocation brackets and a Summit Racing Diff support cover. $800
Old Jun 23, 2018 | 08:06 PM
Toxicant's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.23 4th Gen w/ powertrax locker
Re: 10 Bolt rear end 4.10 gear with Power Trax no slip
How is driving around on this? i just installed one in mine and am looking for some comparisons.
Old Jun 24, 2018 | 06:16 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Drives just fine only thing you really want to do is when making turns either cruise through them or have you foot on the gas. My car gets jerky if it locks mid way through a turn
Old Jun 25, 2018 | 01:54 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
They drive OK, turning radius seemed diminished with mine also with a manual trans you really need to have the clutch out when making tight turns and a little bit of gas or you would get a bunch of clicks and pops.
wakeboardr42393
Sep 19, 2011 06:55 AM
89RsPower!
Sep 21, 2007 10:33 AM
89formula350b2l
Nov 16, 2006 06:56 PM
Electron_Blue
May 8, 2003 08:50 PM
2ponchos
Jun 14, 2002 01:53 PM
