9 bolt rear end 370 and limited slip for 277
Old Nov 12, 2006 | 08:15 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
looking for 9 bolt 370 ish rear end with or without limited slip for my 277 9 bolt.
Old Nov 12, 2006 | 08:40 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I just sold the 3.70 and posi from my 9 bolt, but I still have the axles if you need a spare set.
Old Nov 13, 2006 | 02:43 PM
Car: 92 Camaro
Axle/Gears: S60 373
axles are fine. I appreciate the offer but looking for gears and l/s....any idea where i can get them off teh net?
Old Nov 13, 2006 | 03:27 PM
Bull's Avatar
Engine: LT1; None
No problem at all. Now that I think of it, my gears were 3.23 anyway, not 3.70...must have been tired when I wrote that.
Your best bet might be just to keep cruising the classifieds here, and check e-bay.
Old Nov 13, 2006 | 04:59 PM
Car: 92 Camaro
Axle/Gears: S60 373
thanks
Old Nov 14, 2006 | 03:45 PM
Car: 92 Camaro
Axle/Gears: S60 373
still looking.....
Old Nov 16, 2006 | 11:24 AM
Jeffluke's Avatar
Car: 90 L98 IROC/87 LB9 NM5 1AZ / 96 TBI 350 700R4 XCAB S-10..LT1 SOON
Engine: L98/LB9/LT1
Transmission: 700R4/WC-T5
Axle/Gears: 3:73
I have two rears located in Suffolk Va., 89 9-bolt, posi, pbr larger disk brakes (like the 90-92 cars), w/2:77's, and the original rear from my 87 Iroc w/83k miles: 9 bolt 3:47 posi, small disk brakes, It would be tough to part with the 3:47's, as that rear is a hard one to come by, only on the 5-speed IROC's, and a back up rear for the 28 spline/3:73/10 bolt on the car now.......may part with it as I need a painless LT1 harness to finish my car.
Old Nov 16, 2006 | 06:56 PM
Car: 92 Camaro
Axle/Gears: S60 373
How much for the 347 with and without the posi?
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
