BBK TB 52mm
Car: 1989 Pontiac GTA
Engine: 5.7
Transmission: 700R-4
Axle/Gears: Borg Warner 9 Bolt 3.27
BBK TB 52mm
This sale is for a used, 52MM BBK Throttle Body. I purchased this used for my 89' GTA last year but when I went to install it found out GM changed one of the cable ends in 89' and it doesn't hook up to the throttle bracket. With that said, look at your current setup and match to the pics to make sure it is the same. I called BBK and sent them the pics and this is model# 1534 that fits F-Body's 85-88. Not 89-92 years.
You will have to reuse your old bolts,IAC,TPS and gasket for the bottom piece where the coolant goes thru. It does come with the mounting bolts to Plenum and TB gasket.
Is ready to bolt on and go
$175 + shipping
$175 + shipping
Sickness91Z28
Jan 25, 2003 10:50 AM
vortech305
Aftermarket Product Review
May 19, 2001 03:38 PM
