52MM BBK Throttle Body....worth the money?
Old Sep 26, 2002 | 03:34 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Hey Guys,
I have a 1991 Z28 5.7 Tuned Port Injection (L98).....and I was just wondering if a BBK 52 MM Throttle Body is worth the money and what it really did. Some of my buddies said that they've had the BBK 52 MM Throttle Bodies on their 5.7 TPI's and they said they are worth the money and they noticed a pretty big difference. So.....what do all you guys with 5.7 Tuned Port Injection think about these? Thanks!
Old Sep 26, 2002 | 04:05 PM
kevinc's Avatar
Car: 1982 Z28
The sealed roller bearings on the throttle shaft are nice, stock TBs have bushings which eventually wear and cause the shaft to bind..."why does my car idle at 1500rpm" kinda thing.
The machined/cast inlet area gives similar airflow benefit to an airfoil.
I ran a stock TB bored out to 52mm by SPD (www.spd.com) for years, replaced it w/ a BBK because the throttle shaft/bushings wore out and it was binding. I solved it with an additional return spring for another year, eventually it started binding again.
Old Sep 26, 2002 | 09:23 PM
Thirdgeniroc's Avatar
Car: 86 iroc
Engine: 355 TPI
I have a 52mm bbk t-body I noticed a pretty good difference vrs the stock.The only thing I don't like is how the foil doesn't go all the way out to the edge.Either way you won't go wrong with one it will help.Good luck
Old Sep 26, 2002 | 11:15 PM
AlexJH's Avatar
Engine: 5.7L V8
Not worth the money unless you already have other mods, headers, exhaust, etc.
Old Sep 27, 2002 | 01:01 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Not worth it unless you have other mods.....
example:
GM's ZZ502 is a 500 horsepower 500 cubic inch big block. They use a 48mm throttle body.
Old Sep 27, 2002 | 01:46 AM
rockind78's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=134163
Old Sep 27, 2002 | 07:36 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
A lot of people (a LOT) have found the BBK to be a poorly made unit that caused them a lot of problems. Others have had no problems. I decided to spend $50 more and get the billet aluminum holley, and it's a top quality piece.
Old Sep 27, 2002 | 09:42 AM
5SIZ's Avatar
Car: 1987 IROC-Z
Get the Holley if you decide to go with a TB
But I would honeslty spend hte money else where like on a good Cam or Headers
Old Sep 27, 2002 | 09:56 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I've had the BBK 52mm for over 2 years, no prob. On a stock motor don't expect a gain though.
Old Sep 27, 2002 | 10:20 AM
Engine: 5.7
As far as the engine goes in my 91 Z (5.7 TPI L98), it's basicaly stock.....as far as I know anyways. I have 3 inch cat back 80 series flowmaster exhaust, 3 inch exhaust cut out with both cat's removed. I wouldn't mind to put a cam or headers on....but....I have no idea how to do that kind of stuff......I'm more of a paint and body person. If I can get someone to do some stuff to my engine, I'll do that. But...I just wanted to see id the TB done anything on a stock 5.7 TPI.
92firebirdguy
Sep 1, 2016 07:53 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
Randomtask2
Sep 7, 2015 05:06 PM
Kenwood
Sep 4, 2015 05:50 PM
