[ID] WTS NIB Hooker headers Ceramic Coated$750 PICS (and other stuff)
Old Jun 2, 2018 | 02:58 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
New in box hooker 2210 Ceramic coated headers $750 shipped
save over $100 off.. over $850 at summit..yes fits 82/92 camaro
have a lot of parts going up for sale.. (small block)
and a lot of other part as im going to big block..
UMI wounder bar.. new. un used $65 shipped (red)
edelbrock panrod black and red New un used
this is the trick red anodized adjustable end
with the black body no longer made $90 shipped
lingenfelter TPI TB to 4150 base (4bbl) elbow
want to run a TPI TB on a sigle plane intake ..this is one way.$90 shipped
accel linenfelter 58MM/1000CFM top plate marked
TB w/ all parts as sold with
from my 92 Z 28 $325 shipped
so much stuff... will post pic sat the 2nd
Vortec V1 T trim Cog Drive set up for 88 to 92 TPI (kit)with
polished head unit this is the race unit.. not for the faint of Hart!
used working. good condition no play or slop in shaft..plug and play..
$2300 shipped for $500 more it..
will come with
NIB MSD BTM ($475 from summit)
NIB MSD Billet distributor ($250+summit)
NIB MSD coil ($45 summit)
NIB MSD pig tail plug and play for the TPI set up($35summit)
hooks into TPI set up..
keeping the plug wires...as I can use them on my BBC...lol
also have a complete Accel 300+ set up with billet accel distributor. like new.. working just dusty
will be in accel boxes with paper work $300.
dissy
coil
300+box
EBL P4 ecm/all new in box (never used) price?? you tell me...
$7500 (OBO) YOU GET TO PUT IT TOGETHER! the pic below is it...IT WAS test fit.TO make sure things fit...
427 sbc aftermarket block new in box (boxes) 11.1 with the 72cc heads
short block is assembled (still have shipping crate) it came in..
ONE OFF set of Lingenfelter valve covers the only set like them 1 of 1...what you see is cut into the covers..and inlayed with color...
AFR 220 eliminater heads race ready 72cc(new in box)
MLS head gaskets (cometic)the good ones NIB
AFR stud girdle for this Set of heads
ARP head bolts with SS outer bolts NIB
compcams cam mech roller NIB
compcams pro mag rocker 6.5 NIB
campcams mech roller lifters +300 tall for this block NIB
compcams push rods for this eng head combo correct geometry NIB
compcams tool steel retainers NIB (was a hot new thing)
compcams poly locks SET with the 4 that have snap rings to hold the stud girdle up..sweet
canton racing 7qt oil pan that has every thing
canton oil pump pick up for the above pan
melling hi vol oil pump NIB
ARP oil pump stud kit NIB
Melling oil pump rod NIB
ATI Damper NIB
SFI Flex plate NIB
RHS efi intake polished with FAST fuel rails
kingsler 1050CFM TB Polished (takes GM TPS & IAC)
for $550 more ill toss in the NIB March pully and brakets
CHROME power steering pump
proform chrome electric water pump
almost every thing in pic no alt....I can use it on my BBC...
to much to list!! no rush to sell. as the big block is a done deal!! if it don't sell.. its just going to live in a bag in the shop..
how sad that would be...and if ya want the MSD parts lets just say another $500 and ill toss them in also..why not...as for shipping...we can make a deal on that also...always open..
all of this for under $10.000.... could be....
this intake is also going up for sale as I pick up a shorter (by 1 inch) holley intake so this ones gota go!$650 shipped just paid $400 to polish it
Old Jun 3, 2018 | 06:05 PM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Re: WTS NIB Hooker headers Ceramic Coated$750 (and other stuff)
Pics of accel lingenfelter 58MM TB? Looking for one to go with the super ram I snagged.
Old Jun 3, 2018 | 06:15 PM
ths is a shot of it...when it was on my car..still the same.. just a bit of dust on it in the tight spots..its been sitting in my tool box the last 10 years..it only has 2000 miles on it in its total life...even have a tpis water delete NIB for it but never put it on...
Old Jun 3, 2018 | 06:52 PM
absaraka's Avatar
Car: 1987 Camaro
Engine: 383
Axle/Gears: Working on that
Can I get pics of the headers? Need a set that will clear a T-56 and bellhousing
Old Jun 3, 2018 | 06:57 PM
Car: '89 'ROC
Engine: 5.7L
Damn that looks sweet. Didn’t some member fab the black inserts on the lid of your SR? I’d prolly bite the bullet on shipping to try to recreate that look!
Old Jun 5, 2018 | 01:56 AM
no black Inserts..pic just looks that way..
Old Jun 5, 2018 | 12:31 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
What block is it?
Old Jun 5, 2018 | 06:57 PM
Originally Posted by izcain
What block is it?
if your asking about the 427 block.. its branded Wheeler.
all ARP studs and rod bolts
SRP Pistons
screened lifter valley
all splayed 4 bolt on the mains..
H Beam rods. billet main caps
even 4 bolt on the oil cap end
all forged bottom end..
how it will ship out
Old Jun 5, 2018 | 07:30 PM
this Vortech unit is a full kit with all parts..brakets..plate...bolts..belts...lines..
so many goodies
still new in boxes
headers
Old Jun 5, 2018 | 07:35 PM
oil pan for the 427..has all the things ya can add to a oilpan…windage try..crank scraper..trap door....bung for dip stick..bung for temp gauge. oil return for turbos or blower...its got everything
Old Jun 5, 2018 | 08:21 PM
Car: '89 'ROC
Engine: 5.7L
Re: WTS NIB Hooker headers Ceramic Coated$750 PICS (and other stuff)
You killed Santa! What’s the driveshaft?
Old Jun 5, 2018 | 08:32 PM
drive shaft was aftermarket aluminum 3 1/2" sold last year..
Lingenfelter elbow 5 1/4 tall
still like new..been sitting for 25+ years
still new in bag
Old Jun 5, 2018 | 08:40 PM
nice combo
articwhiteZ
Jun 11, 2018 07:24 AM
DAHULK2000
Feb 22, 2002 04:56 PM
F0xBody50
Jan 21, 2002 12:15 PM
MCMLXI
Dec 21, 2001 08:25 PM
82LR
May 3, 2001 10:20 PM
