[IL] SOLD! Moser 12 bolt '82-'02 with Yukon carrier, 33 spline axles, and brakes!
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
SOLD
Brand new never installed F-body Moser 12-bolt. 4th gen width, but fits gen 3 '82-'92 F-bodies as well. Located in Niles, IL on the Chicago border 60714.
$1550
Comes with :
- Moser housing with chrome cover, cover bolts, and torque arm bolts.
- 33 spline Moser axles
- Yukon Gear & Axle Duragrip 33 spline posi carrier
- '98-'02 LS1 Camaro disc brakes, hard lines, parking brake cables, brackets, and bolts.
- Axle bearings, axle seals
- Pinion seal
- T-bolts
$1550
Comes with :
- Pinion seal
- T-bolts
Car: '91 LS6/T56/9"
Engine: LS6
Re: Moser 12 bolt '82-'02 with Yukon carrier, 33 spline axles, and brakes!
Thanks, but I can see them fine. They're HTML embedded so you many not be able to see them on a mobile device.
I'm on a desktop (tried in Firefox and Chrome...same result). You probably have your file sharing permissions set to be viewable only by you. Just trying to help.
Car: '91 LS6/T56/9"
Engine: LS6
Should be fixed, thank you.
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
Pm sent
Car: '91 LS6/T56/9"
Engine: LS6
Sale is pending. Will update if it falls through.
pboxfun
06-20-2014 09:47 AM
kowboy59
06-23-2013 01:06 PM
91_B4C_RS
03-17-2011 07:32 AM
Night rider327
09-08-2004 08:32 PM
