Holley HP/Avenger/Terminator ECU with Main Harness
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
..... SOLD … SOLD … Holley ECU with main harness and handheld controller … This ECU has an Avenger label but the Avenger , HP , and Terminator are identical internally … the sticker is the only difference (ask Holley Tech) … includes a MAP sensor and a Bosch Wide Band O2S … $1100 shipped to the lower 48 …..
Car: '87 Vette C4
Re: Holley HP/Avenger/Terminator ECU with Main Harness
….. I don't know the exact part number … the tags on the ECU end of the harness are illegible … but it matches the harness on my car for MPFI / single plane set-ups … flat 4pin IAC connector … flat 3pin weatherpack for TPS … 2pin weatherpack for MAT (adapter needed) … flat 3pin weatherpack for MAP … you will need an injector harness and an ignition adapter (depends on your ignition type) …..
Car: '87 Vette C4
….. Sold ! …..
C409
12-01-2014 04:32 PM
