[MN] Many Random Parts. 3.8L series 2, 5.3L, A/C and Turbo Stuff
Car: 1989 IROC-Z
Many Random Parts. 3.8L series 2, 5.3L and Turbo Stuff
T5 inspection cover
3.8L series 2 starter
3.8L fuel pressure regulator pn 22849
3.8L metal coolant elbows
3.8L heater hose repair kit
SBC high volume/high pressure oil pump. New w/ surface rust. Pick up welded in place. Comes with spring to return pressure back to normal pressure.
89 5.0/5.7 Energy suspension poly motor mounts
March Underdrive crank pulleys. I have 2
Comp Cams SBC push rods pn 7812-16
Turbosmart street-gate 38mm wastegate
“purple” wastegate spring
Jodar 50mm blow off valve
Summit SBC timing chain set. New in box pn G6600
Fel-pro TPI intake gasket set. pn MS 93035-1 (some gaskets are missing)
3.1/3.4/3.8L PCM pn 16211539
3.8L PCM pn 16227797 97 Camaro/Firebird
3.8L PCM pn 16207326 95-96 Camaro/Firebird
86-89 TPI PCM pn 01227165 w/ factory PROM
SPEC aluminum flywheel w/ stage 3 clutch. ARP clutch and flywheel bolts included. 3.8L V6 Camaro/Firebird
2” mandrel bends 2 90* and 2 45*
Make offers on anything, motivated to move these parts. I’m in the middle of an LS1 swap so if you have anything LS swap related you’d like to trade/sell please let me know. I have pictures of everything.
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
Re: Many Random Parts. 3.8L series 2, 5.3L, A/C and Turbo Stuff
will the headers fit a 2.8? I dont know much on the 3800 stuff. I am interested if the do
Car: 1989 IROC-Z
Pretty sure they won’t fit but I’m am also not 100% sure.
Looks like a no
Car: 1989 IROC-Z
Car: 1989 IROC-Z
Bump, updated sold parts and added a couple extra parts.
84'B.A.T.A.
Jan 31, 2014 11:10 PM
chimera2223
Oct 16, 2013 10:14 PM
19911LECAMARO
Sep 11, 2009 10:59 PM
Jay87Z
May 25, 2009 09:35 AM
