COMPLETE Auto to TKO 600 conversion
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Included will be EVERYTHING to convert an auto car to TKO 600 5 speed. These are top quality high performance aftermarket and stock parts. Below is what you get;
TKO 600 transmission. GM spec for 3rd gen. Upgrades are carbon synchros, polished shift rails and detents and brass sliders & all seals were replaced with new output bushing. ~1000 miles. Includes mech speedo bullet with a few different gears for different ratio rear ends. Also has electronic speedo sender. Fluid was changed regularly.
Lakewood scatter shield and motor plate for 3rd gen with slave mount (Minor clearance for exhaust and oil drain mods) Accepts TKO, Muncie/Saginaw or stock T5 trans.
McLeod RXT dual disc clutch. About 6 months old or can be refreshed if desired. This is an awesome clutch set. Includes TOB.
26# SFI steel flywheel. 153T "0" balance for 2 piece rear. (or use any 153T flywheel)
Steeda short throw shifter with lever and **** for Camaro. **** positioned in "stock" location. This is a custom fab lever. May work for Firebird/TA
5 speed console plate. Camaro only.
Shifter boot that goes under console on trans tunnel
Brake and clutch pedal assembly. Includes both braces for firewall.
Metal master with adjustable rod. Master and slave are in great condition.
Stock slave with braided steel line kit
Custom drive shaft with correct yoke for TKO. Solid Spicer u-joints.
All bolts for the above. Flywheel, trans etc.
$3500 for everything. I originally converted from auto so this is a complete package from flywheel to driveshaft, clutch pedal to transmission. Shifter, console plate and related. This transmission is well built and tough as nails. It performs flawlessly and takes 4000 RPM launches with slicks. I just want to go back to auto for consistency. Trans is currently installed in vehicle so you can drive and check it for yourself if desired. If we make a deal it will take a week to pull. I can palletize for shipping or you can pick up locally.
I may consider partial trades for 700 or 4L80 transmission. Contact me if you have any questions.
Car: 89 IROC
Engine: 6.8 HSR N2O
Re: COMPLETE Auto to TKO 600 conversion
Update, I'll also include a "Clutch Tamer" device custom fit with brackets for Camaro. May fit Firebird as well. This is a great addition and makes shifts easier by keeping the pedal at the friction point during fast upshifts.
jonnybcamaro
Oct 22, 2008 08:21 PM
IROCFAST
Nov 3, 2007 11:03 AM
89formula#1
Apr 2, 2005 12:51 AM
